Caliper bracket fitment 2007 <-> 2012 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 1 Old 08-23-2013, 06:08 PM Thread Starter
Question Caliper bracket fitment 2007 <-> 2012
I recently took on the task of replacing my brakes and with some searching I manage to find a new caliper by motorcraft on E-Bay (BRC-230RM). After failing to get it on the vehicle I found out that its not even for my truck a 2007 F250 6.0.
This caliper is wider than my 2007 caliper bracket and the real trouble is, I've gone through and put red caliper paint on this one! So I was hoping someone out there could do me big favor and measure the bolt pattern of the 2007 caliper against the 2012.
The measurements of my caliper bracket holes that fit the caliper pins are 18 cm, center to center. The measurements of the holes that bolt it onto the frame are 16 cm center to center. If it turns out the 2012 bracket will fit, I'll just go buy a 2012 bracket and be set to upgrade both rear brakes. if not well... Shoot.
Thank you!
2007 F250 Lariat Outlaw
Rebuilt transmission from BTS, Head studs, Banks inter-cooler, Air bags, Air compressor
snowmobile74 is offline
