16" rims, how big can my tires go? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 08-21-2013, 04:52 PM Thread Starter
It is time for some new tires and I'm wondering how big I can go on my stock 2003 F250 super cab 4x4 without any issues like rubbing. Have been looking around and have not found and definite answers.
I use this truck just as a daily driver currently, and I do tow sometimes with it, nothing to crazy though. As far as off-road, mainly just driving through fields and the occasional muddy roads.
Anything helps.
Cheers
MrMikeF250 is offline
post #2 of 7 Old 08-21-2013, 06:39 PM
JustinOOO9's Avatar
Quoted: 419 Post(s)
Garage
Whats the current size your running and can you take a tape measure and measure the distance from top of tire to fender and then the front and back of tire to fender (probably at an angle) and whats your wheels offset or back spacing?
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes,
currently-1999 F250 SBRB 4X4 First 7.3, 6.0 trans cooler made my muffler fall off
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 7 Old 08-23-2013, 12:41 PM Thread Starter
Driver side front. 7 3/4in. Top of tire to fender.
2in from tire to front fender. 2 1/4in tlfrom tire to rear fender.
Passenger side front. 8 1/4in. Top of tire to fender. 2 1/2in from tire to front fender. 2 1/4in from tire to rear fender.
post #4 of 7 Old 08-28-2013, 02:14 PM
I think that you're limitied more by the rim width that the available space. Those tires are roughly 31.5 tall, you could go to a 33 inch tire w/out any suspension changed. However, the narrowest 33 on a 16 is a 285/75. I had 285s on an 8 inch wheel and needed to run about 40ish to prevent riding in the center. I put them on 10s, aired up to 50, and all was good.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 7 Old 08-29-2013, 07:20 PM
Joel's Avatar
Quoted: 10 Post(s)
255/85-16 is a match made in heaven for a dually on stock suspension.
Selection is limited, but Toyo makes em in both the M-55 and the mud terrain
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 7 Old 09-02-2013, 06:38 PM Thread Starter
Guess ill be doing 285's. Now what tire to pick. Was going to do bfg at's. Any suggestions? I hear bad and good things about all tires on here. I just need a good pair of nice looking tires.
post #7 of 7 Old 09-08-2013, 11:02 AM
KS_
Quoted: 22 Post(s)
I have an obs.. but. I think these are great tires (Firestone Destination M/T's 285/75 16's) a/t's are about the same in tread too, and they look amazing. Quite wide looking and the inside rub was fixed with $30 quarter inch spacers. but on your truck theyll probably be perfectly fine.
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
