Will this work? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 08-16-2013, 08:06 AM Thread Starter
Will this work?
Okay guys the I have a 2011 with the 20x8 +40 offset rim package. I wanted to put on 35x12.5 on 20x9 0offset XD misfits. Now this will bring me closer to the hub and thus the control arm.
My buddy runs some incubus 18x9 with a +18 offset and has no rubbing is approx 1-1.5" from rubbing the control arms. Now If I ran those wheels (mifits) and ran a .5" wheel spacers technically it wouldn't rub?
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #2 of 12 Old 08-16-2013, 09:31 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You can't use 1/2" spacers studs are to short.
CT Performance, Inc. is offline
post #3 of 12 Old 08-16-2013, 09:47 AM Thread Starter
Well lets say a 1.00" inch spacer in this case then.
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #4 of 12 Old 08-16-2013, 10:00 AM
Quoted: 3 Post(s)
NO, min spacer would need to be 1.25" Hub to wheel centric. we have them. You will also have to cut off the excess wheel studs using a spacer under 2"
post #5 of 12 Old 08-16-2013, 10:07 AM Thread Starter
The more I learn thanks Cary, just going to level it and not worry about spacers!
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #6 of 12 Old 08-16-2013, 10:43 AM
Quoted: 3 Post(s)
That still may not stop the rubbing...on stock but since the new rims, 20x9 0offset XD misfits are 4.5" BS where as the stock Fords are 6" BS the rim will move out 1.5" from the radius arms.
remember offset NEVER matters its BS that is important.
post #7 of 12 Old 08-16-2013, 11:34 AM Thread Starter
I thought the misfits are 5.0BS?
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #8 of 12 Old 08-16-2013, 11:51 AM
Quoted: 3 Post(s)
Yep my bad..here is a chart, center of wheel is from the inside face so...the rim will stick out 1" farther from the inside which will help the rubbing on the arms.
https://www.rsracing.com/tech-wheel.html
post #9 of 12 Old 08-16-2013, 12:04 PM Thread Starter
So less backspacing will increase the distance from the mounting flange on the hub to the inside lip of the wheel correct? Then technically a negative outset would put the rim further out to clear the a arms
2004 F350 PSD
2011 F350 PSD
20046.0 is offline
post #10 of 12 Old 08-16-2013, 01:07 PM
Quoted: 45 Post(s)
I disagree.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
