Leaf spring rub fix? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 08-12-2013, 12:48 PM Thread Starter
Hi all. I recently purchased an 01 F250 7.3. It came with Falken Wild Peak tires size 37/12.5/17. It has a spring leveling kit on the front, not sure the height. It rubs on both sides when the wheel gets somewhat close to lockout. Is there a way to fix this without cutting, fabbing or chopping something myself? I don't really want 37s anyways, but the only 33 and 35" tires I have seen are still 12.5" wide. Maybe I just need to look harder? If I find tires that are maybe .5-1" more narrow, will it make much of a difference? Sorry for the stupid question, but I literally have no idea what to do with tires this big.
optimusprime is offline
post #2 of 5 Old 08-12-2013, 07:04 PM
BIG Laing's Avatar
The 17" wheel is limiting you with metric tire sizes. The tallest skinny tire I know of is LT295/70R18 which is 34.5x11.8
Are these the stock wheels? You could get new wheels with the correct offset/backspacing to prevent you from rubbing the leafs.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 5 Old 08-12-2013, 07:29 PM Thread Starter
Thanks for the response BIG Laing. These are not stock wheels. I honestly am not sure what brand they are. They are 8 lug, not sure the nut size. I don't have my truck right now since it is in the tranny shop so I can't even put a pic up for you. Sorry. What do you mean by correct offset and backspacing? I apologize for my lack of knowing pretty much anything. I'm such a n00b.
post #4 of 5 Old 08-16-2013, 07:19 AM
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
You could throw on some wheel spacers to push the rim out from your leafs.
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #5 of 5 Old 08-16-2013, 08:26 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You need 4.5" BS then if the axle is centered and using 12.5 tires it shouldn't rub the springs.
Rubbing the fenders is from a incorrect lift for the tire size.
PM me if I can help
CT Performance, Inc. is offline
