Biggest tire for 16x7 stock rims - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 08-05-2013, 07:01 PM Thread Starter
I have a 2002 f250 7.3 diesel Lariat 2x4 with stock rims which I believe are 16x7. Current tires are Michellin 265x75x16. Also have a 2" level kit up front. Wanted to know if anyone is running 285x75x16 on these rims. Discount tire says no, others say yes. What's the real story? Thanks!!
Echuber is offline
post #2 of 7 Old 08-05-2013, 07:10 PM
Colin7.3's Avatar
Yes you can. That is what I'll be running soon
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 7 Old 08-06-2013, 03:13 AM Thread Starter
Thanks Colin. Anyone have any pictures or can comment on tire bulge, etc? Also wanted to know how they handle and wear, although I realize wear is much a function of tread type and brand. Thanks
Echuber is offline
post #4 of 7 Old 08-06-2013, 03:50 AM
BIG Laing's Avatar
Although that is a sweet tire size, usually an 8 inch wide wheel is Nominol with a 7.5 inch wide wheel as a minimum. Discount will not mount a tire on a wheel that is not within the manufactures specs.
Gotta find a ghetto tire shop.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 7 Old 08-06-2013, 03:51 AM
BIG Laing's Avatar
They will mount 265/75r16 for you...
post #6 of 7 Old 08-06-2013, 11:41 AM
When the rim is that much thinner than the tire, the tire WILL stand up in the middle as psi goes up. I have seen 285s on factory wheels, and running at max psi, the outer shoulders don't even touch the ground.
I ran my 285s on a 10 inch wheel and had NO tread wear issues at 50 psi. You don't need to fiddle fart around with the suspension to run a 285 on a 10 inch wheel, either.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 7 Old 08-07-2013, 04:12 AM Thread Starter
Thanks for all the responses. Sounds like lots of folks put 285s on stock 7" rims but its not optimal. The 265s are just kinda small and we don't really want to buy new rims. May have to delay the tire purchase until we can save for the rims. Appreciate it!
Echuber is offline
