Incredibly Disappointed with Nitto Grappler - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
 1Likes
post #1 of 93 Old 08-04-2013, 10:46 AM Thread Starter
scotiadallas's Avatar
Hey All,
I regularly read and sometimes post on this forum. I try to do my best to share information that will be useful to other F250 owners. This forum has saved me a lot of money in the last few years.
Before I purchased tires, I tried to read as many posts on this forum as I could.
I wanted a tire that looked great and gave my truck a more aggressive appearance, was good in the winter and had reasonable wear.
Based on what I read, I chose the Nitto Grappler MT.
I almost chose the Goodyear Duratrac or the BFG TA
I had them mounted on a 18" black Rockstar wheel with an offset and a they look fantastic, really fantastic. Fattens the look of the truck and gives it that little bit of stance this truck needs, IMO. I couldn't complain about the look, it finishes off the truck of my dreams.
BUT, the wear on this tire is absolutely, ridiculously poor. I can't stress enough on how quickly this tire wears. I've had them ONLY 10 MONTHS and they are almost done. I'm not far off of the wear bars and I suspect that they will be finished in a year.
You are probably wondering about milage? I put below average milage on this tires - I work from home, I don't commute and I have only towed on these tires for 700kms. To save the tires, I swap wheels when I go on a long tow. I just came back from a 12,000km tow, if I would have left the Nittos on, they would be slicks. I would say I am an average or below average distance, or at least I have been on these tires because I took them off during my longer drives.
I'm 70% on pavement, 15% on dirt-roads and 15% off-road.
Anyway, I need to post my disappointment with these tires. I don't know if I received a bad set but if this is normal, DO NOT PURCHASE THESE TIRES.
I made a $1400 mistake with these, I hope someone can learn from my error. I am mostly just venting and warning others of my experience.
Any comments and opinions are welcome.
D
scotiadallas is offline
post #2 of 93 Old 08-04-2013, 10:50 AM
mazsecond's Avatar
Feedback Score: 4 reviews
Do you have the Trail Grapplers or the Mud Grapplers?
mazsecond is offline
post #3 of 93 Old 08-04-2013, 11:06 AM
The mud grapplers are very soft, while the trails are a harder rubber, kind of a street queen tire. They hook up good in the mud, but not like the MUDs.
Moto2four is offline
post #4 of 93 Old 08-04-2013, 11:11 AM
sprksonu's Avatar
I have to agree nitto tires suck! I had a set of the terra grapplers and only lasted 18k miles and that was all highway miles with no smokey burnouts, so I decided to get the toyo open country a/t's have 43k miles on them with plenty of meat left. On my work truck I have the toyo open country m/t's and have 32k miles on them with a lot of meat left as well
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #5 of 93 Old 08-04-2013, 12:00 PM
theplumbingmedic's Avatar
I have the duratrac`s and have had them on for 16000 miles and they seem to be wearing great. i rotate them every 5000 with the oil change
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #6 of 93 Old 08-04-2013, 01:03 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
HOLLY KRAP with those results I guess Ill stick with my BFG's. Thanks for the heads up.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 93 Old 08-04-2013, 02:41 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
I have the nitto dune grapplers and they didn't last for sh!t, I got the truck used but the tires were either brand new or just a few hundred miles. I already need to replace them and I have almost put 24k miles on em. Poor wearing! Good lookin tire and it's quiet but don't last worth a sh!t!
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #8 of 93 Old 08-04-2013, 03:42 PM Thread Starter
MUD Grapplers, maybe I should have went with the TRAIL.
post #9 of 93 Old 08-04-2013, 06:47 PM
Quoted: 3 Post(s)
For a daily driver that doesn't see mud, yes, you should've went with the trail graps. The mud graps are known to wear quicker than AT tires but that's because of our heavy trucks and soft rubber compound. The tires are made for the mud, and they perform excellent in it, they just don't last very long. I have 7k miles on mine and they still look brand new
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #10 of 93 Old 08-07-2013, 05:28 PM
TOYO M/T!! these tires are the sh!t. I rode in a cummins off road with brand new nitto muds and he was spinning in 4x4 up a soft hill +-35% grade, absolutely pitiful, they are loud ugly and dont perform well in mud. He ended up getting 25k out of them and they are slicks. My toyos have 10k almost all rock/pavement/chip-seal so far and look brand new, quiet and sexy looking, they are e load rating, and i wouldnt buy a different mud tire. They are perfect! I hate the nitto mud as much as i hate black rims and thats a lot!!
STECKSTROKE1999 is offline
