Ok yes another 16.5 wheel question. - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 32 Old 08-03-2013, 05:00 PM Thread Starter
Strokergonebroke's Avatar
Ok well ive searched and searched and cant find the answer to my questions.
I have 4 humvee tires W/ full rubber run flats, dot approved goodyear's straight off base, but obviously ford screwed us with the lug patterns.
#1: If i buy Mickey Thomson 16.5 wheels will these tires stay on at normal psi and be safe to put my daughter in the truck...i do wheeling but never air down or anything like that.
#2: If I were to go and buy some trail worthy fab custom wheels, can i run them as DD safely(again i have a daughter).
#3: What back spacing should i run? I have after market wheels now with 4.5 but i truelly love the wide stance look...is a 2.5 backspacing to agressive or just go 3.5...yes i know I might have to cut my bumper but thats ok, i only have a 4inch lift anyways so the 37's will rub regardless for now.
Thanks for the input guys.
-Ed
2004 6.0...studded,sinister coolant filter,updated turbo lines,oil cooler,fuel spring,egr delete, 6in lift, 37 military tires, looney'd and podded.
Strokergonebroke is offline
post #2 of 32 Old 08-03-2013, 05:13 PM
ZMANN's Avatar
Quoted: 1771 Post(s)
not that this answers your question but here is My 2 cents
I have 16.5's on my Blazer they were High $$ Rims and bought years ago just before they basically did away with them as the norm 8 lug rim
I will need new rubber some day And I think it would be time to ditch the rims
and get a saftey bead on say an 18 " like I have on My Superduty
We Miss you Ronnie
ZMANN is offline
post #3 of 32 Old 08-03-2013, 05:18 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 110 Post(s)
Feedback Score: 7 reviews
i wouldnt put my daughter in a truck with militray tires (used ones at that) without having them beadlocked.
try and find a 16.5in rim that is beadlocked, regular 16.5 dont have a bead to retain the tire like the other size rims do. if safety is paramount, stick with a 16/17/18/etc rim size.
just my opinion but being military... i have seen what those tires go through.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 32 Old 08-03-2013, 05:25 PM Thread Starter
Well that goes to my second question. If trail worthy fab wheels are good for DD then ill just buy a set of those.
My issue is $1400 on tires is down right stupid when i can get the humvee wheels for $150 set of 4 with 90% tread.
4 tires at $350 = $1400
4 TWF wheels at $200 = $800 but tires are time a dozen
post #5 of 32 Old 08-03-2013, 06:27 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
just get the military tires, your a idiot if you pay anywhere near those prices for tires
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #6 of 32 Old 08-03-2013, 06:48 PM Thread Starter
Well then explain to me were you get your 40 pro-comp wheels for any cheaper eh?
post #7 of 32 Old 08-09-2013, 02:48 PM
The issue with 16.5s breaking the bead out wheeling is when they are aired down. If you don't air down, then it's a self correcting situation as I see it.
Unless the tires are cut or the sidewalls split, I would run them on my rig. In fact, I have a set of 16.5 Convo Pro Centerlines in the garage for some military 37s eventually.
Karl
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 32 Old 08-09-2013, 03:24 PM
I wish someone would try them on something with the same sized brakes as a 06.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #9 of 32 Old 08-09-2013, 03:36 PM
ZMANN's Avatar
? what are you after ? ?
yes the demise of the 16.5 was the lack of retention when proper air pressure
was compromised and since you have no control if you get a puncture
you have no control whether your tire leaves the seating area and causes a roll over or complete lack of steering etc
We Miss you Ronnie
ZMANN is offline
post #10 of 32 Old 08-12-2013, 09:38 AM
yes the demise of the 16.5 was the lack of retention when proper air pressure was compromised and since you have no control if you get a puncture you have no control whether your tire leaves the seating area and causes a roll over or complete lack of steering etc
While I am not devaluating this statement, I would think that a blow out on a lifted front could have the same hazards.
Karl
Karls03 is offline
