38" Rubber - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 07-29-2013, 03:35 PM Thread Starter
38" Rubber
2012 F350 with a six inch Rough Country suspension lift plus 2.5 inch Readylift coil spacer and rear add a leaf... will a 38x15.50x22 fit? im willing to cut and grind fenders and bumpers but want to know if anyone else has done this. Im currently running 22x11 - 24 Fuel Cranks and 37x13.50x22 tires.
Rhino7777 is offline
post #2 of 5 Old 08-03-2013, 11:09 AM
joeyk5150's Avatar
I'm looking at doing a similar setup on my 08': 8" BDS 4 link lift, 20x12 Fuel Hostages, and havent decided on 38x13.50 or 38x15.50 Toyo M/Ts yet. Why did you decide to go with wider tires? I only ask b/c I dont want to buy one or the other and regret it.
2008 F250 Lariat 4x4 CC SB Spartan tuned, AFE intake, DPF/CAT delete, MBRP filter back exhaust, 2.5" leveling kit on 35x12.50x20 ATZs
joeyk5150 is offline
post #3 of 5 Old 08-04-2013, 07:31 PM
Gburow's Avatar
Is there any way I could get a measurement from top of hub to bottom of fender on the front? I measured a stock truck and was 8" higher but only have a 6" zone lift
Sent from AutoGuide.com App
Gburow is offline
post #4 of 5 Old 08-04-2013, 07:32 PM
Gburow's Avatar
The reason I ask is that I'm debating on going to 38x15.50 and want to know if i will clear or not. My truck sits 2-3" taller then my fathers 08 with a 6"
Gburow is offline
post #5 of 5 Old 08-06-2013, 04:39 PM
6.4lmonster's Avatar
It should work with 8" of lift im running 20x10 -12mm offset with a 6" fabtech with the 38x13.50 toyos no rub at all couldnt run the 15.50 on mine with just the 6"
2008 F250
SPARTAN 300 HP TUNE
HEAD STUDS
DPF/EGR DELETED
SB INTAKE
4" DOWN PIPE & STRAIGHT EXHAUST
6" FABTECH LIFT
20X10 XD MONSTERS
38X13.50X20 TOYO'S
6.4lmonster is offline
