37's - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 28 Old 07-28-2013, 02:47 PM Thread Starter
37's
Can I put 37's on a stock 06 f350 with minimal rubbing until I get leveling kit?
06 F350 KR / 12 sprinter 323bhs
tomsws6 is offline
post #2 of 28 Old 07-29-2013, 12:09 AM
mustangmike6996's Avatar
Im gonna go on a limb and say no. From what I have read, 35s barely clear.
I have an 04 F250 Harley Davidson with the stock 18s I will be attempting to put a 2.5 leveling kit and 35x12.5x18 Cooper STTs or Toyo MTs.
I have done much research and it seems that Its a 50/50 whether or not 35s will work, so like I said, Im pretty sure 37s are a no-go. Maybe someone else can chime in with the 05+ coil spring front end, I believe they will rub the fenders and radius arms tho.
mustangmike6996 is offline
post #3 of 28 Old 07-29-2013, 12:15 AM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
35s will not fit without a rub on an 05-07 body style... So 37s no way
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #4 of 28 Old 07-29-2013, 12:24 AM
BIG Laing's Avatar
no way 37's will fit.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 28 Old 07-29-2013, 05:31 AM Thread Starter
So even with a 2-3 inch leveling kit its a no go?
tomsws6 is offline
post #6 of 28 Old 07-29-2013, 06:42 AM
I have a 4" lift with 35s and 37s wouldn't fit without sheetmetal contact. Sheetmetal, not inner fender or leafs, sheetmetal. If you don't mind using a BFH or a sawzall on the trailing edge of your wheel openings, then 37s are going to need a 6" lift. A simple square tube spacer between the frame and bumper works wonders too.
Karl
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #7 of 28 Old 08-09-2013, 05:56 PM
Quoted: 15 Post(s)
That wasn't really the question. The question was UNTIL you get it leveled, I'm gonna say the answer is no. I bought my 2005 F250 already leveled, my most recent set of tires were 37x12.5x20 Yokohama Geolandar ATS on factory Harley 20" wheels. When the tires were new they just barely rubbed the lower rear wheelwell on both sides at full lock. After a few thousand miles that disappeared. A wider 37" would most definitely have radius arm contact. Mine have polished vertical stripes on the arms but I have never heard or felt it. Keep in mind that tire sizing can vary from one brand to another and even between different tire models in the same brand. My tires work with a leveling kit but it is certainly crowding the limits in all directions. They might also be a tad shorter than other 37s which could be the reason I was able to get away with it. I don't believe that 37s would work on a stock truck under any circumstance and any wider, taller, or more aggressive than mine and they don't make sense for a leveled truck either.
David Frost
2005 F250 Harley 6.0 CCSB
Towerguy is offline
post #8 of 28 Old 08-09-2013, 10:24 PM
No, I have a lift and they still rub a bit while turning.
alradco is offline
post #9 of 28 Old 08-18-2013, 06:37 AM
SlimJim SC's Avatar
Nope. I have 37s on a 6" lift and they rub the inner fender sometimes and leafs if I am backing up. I have a -24 offset.
SlimJim SC is offline
post #10 of 28 Old 08-18-2013, 07:15 AM
CSIPSD's Avatar
Guys...
The OP'er has a 2006 truck. The suspension is completely different. Still doesn’t change the fact that the 37's would not fit without a lift, but I have seen TONS of trucks run 37's with 3" leveling kits on the 2005-up trucks.
Originally Posted by Karls03 View Post
I have a 4" lift with 35s and 37s wouldn't fit without sheet metal contact. Sheet metal, not inner fender or leafs, sheet metal. If you don't mind using a BFH or a sawzall on the trailing edge of your wheel openings, then 37s are going to need a 6" lift. A simple square tube spacer between the frame and bumper works wonders too.
Karl
37's on a 4" Revtek lift... No rub, no sheet metal... Just the proper offset on the wheels...
Too much positive offset...
Again offset...
Suck those wheels in.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
