Cut Out Flares + X-code Spring... how big to go?? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 07-23-2013, 01:51 PM Thread Starter
Hey all looking for some suggestions on wheel offset and back spacing. I prefer the big tire look with only a little bit of lift so I'm planning on doing Cut out flares, X code leaf springs and maybe a small 2.5" leveling kit/3" hangar lift. I figure this will make room for a 36 or 37 " tire. So 2 questions, one what do you think the chances I could squeeze a 38" tire on? and 2) what backspacing and offset would be needed so I don't rub the leaf springs? I can cut the bumper if that get to be and issue as well. I'm planning on sticking to a 17" or 18" rim with beadlocks. Thanks for the help.
YT250 is offline
post #2 of 12 Old 07-23-2013, 03:07 PM
Quoted: 816 Post(s)
Yr make model???
Corey@CNCFAB is offline
post #3 of 12 Old 07-23-2013, 03:19 PM Thread Starter
My Bad its a 2001 F-250 ext. cab long box, has 285/75R16's on it right now with sagging V-code front springs
YT250 is offline
post #4 of 12 Old 07-23-2013, 04:18 PM
1999-2004 use a 4.5 backspace. That would be a -25 offset on a 10 inch wheel. Remember, different widths use different offsets to achieve the same backspace.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 12 Old 07-23-2013, 05:42 PM
Quoted: 816 Post(s)
If you v codes are shot. X codes will give you 3-3.5" without the added 3" hanger kit. You may want to do x codes first to see how u like it before you buy the hangers. Glad to see ur not using mini packs too, I hate them things. Its just one more part in the equation that doesn't need to be to get the results you want. Plus you'll get a more factory look and less axle wrap with x codes
post #6 of 12 Old 07-23-2013, 07:54 PM Thread Starter
Hey thanks for the info folks, so if an x code might give me 3" of lift over what i have now (the springs r sagging enough that my arb diff cover wont fit without any griding) any chance a narrow 38" tire would be an issue?? My other option is zone off road has a 1" hangar lift so I don't have to do the 3" ic
2001 Ford F-250 Ext. Cab Long Box, Ford AIS intake, ISSPRO EV2 Gauges, Aero Turbine Muffler, FRx, HPx, Detroit TrueTrac, 08 Tailgate, 08 rear diff cover, Warn Hubs,lightforce lights, Recon tail lights, Access Tonneau Cover, access add a rac, Firestone air bags, Titan fuel tank, alpine stereo oh and the cruise control & A/C actually work how....
YT250 is offline
post #7 of 12 Old 07-23-2013, 07:58 PM Thread Starter
The 3 " icon lift, will a 10" wide wheel and a 13.5" tire be a problem?
YT250 is offline
post #8 of 12 Old 07-23-2013, 08:21 PM
Quoted: 816 Post(s)
Going with a 38" tire your going to need alot more offset than -25mm. The biggest issue of tire clearance is rubbing the leaf springs. Not so much the fender itself as long as you go up. Which is easier to fix than trying to find a wheel that you really like with enough negative offset. Push comes to shove you can get wheel spacers but that's kind of a last resort. Which that's the boat I'm in.
post #9 of 12 Old 07-23-2013, 08:51 PM Thread Starter
Thanks for the good advice! wheel spacers are not going to happen! So I should be ok with the flares, a 1-3 inch hangar lift and/or x code springs and a 36/37" tire on a rim with 4.5" back spacing/-25mm offset? I'm really more interested in running a decent sized tire and and will be fine with whatever beadlock rim will work. hucorey how much lift r u running with the 35's?
YT250 is offline
post #10 of 12 Old 07-24-2013, 04:54 AM
I've seen 38s on 2003 on 16x10s with -25 offset (4.5 backspace), the only reason he go rid of the 38s was that they were too expensive to replace. Of course he had an 8" lift, too, so that maybe why there was no contact issue.
At any rate, going to less backspace (more negative offset) will get the tire away from the springs. The equal and opposite effect is that it will get closer to the bumper/sheetmetal when turning. Without spending the big bucks on Centerlines or Welds, I don't think you're going to find a backspace less than 4.5" for a reasonable cost.
Karls03 is offline
The Following User Says Thank You to Karls03 For This Useful Post:
1997PSD (07-14-2014)
