What's killing my mpg - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 16 Old 07-05-2013, 02:47 AM Thread Starter
factoryflood's Avatar
Recently switched from a set of 34.8x12R22 +12 offset terra grapplers to a set of 35x13.50R18 -12 offset Mickey Thompson mtz.
Is it the width, the tread pattern, the change in offset, or the weight difference in the tires?
Went from 19.2 hand calculated to 16.1 hand calculated.
Andrew
Sent from AutoGuide.com App
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #2 of 16 Old 07-05-2013, 03:48 PM
heisman01's Avatar
Quoted: 61 Post(s)
Offset doesnt have anything to do with mpg, the tread and width will be your main culprits. Your weight should have gone down as you went from a 22" rim to a 18" in most cases. Try with another tank and see what numbers your getting.
heisman01 is offline
post #3 of 16 Old 07-05-2013, 04:58 PM
I went from 365/65-16 Toyos to 315/75-16 BFGs and thought for sure I would pick some mpg due to the weight loss, nope! Therefore, I think another tank or two would be a good idea.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 16 Old 07-05-2013, 06:17 PM
BIG Laing's Avatar
Offset does come into play when your going from stock, to an extreme -offset. But in this case I would say width is the biggest killer.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 16 Old 07-05-2013, 06:34 PM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 125 Post(s)
Feedback Score: 7 reviews
Probably a heavier combo... More rolling resistance, air pressure in the tire. Load range, etc.
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #6 of 16 Old 07-06-2013, 01:33 PM Thread Starter
Both tires were load range E, been through 6 tanks with these tires nothing has changed about my driving habits yet I'm getting a significant drop in mpg. The width is roughly 1 inch wider than my old pair. In guessing its weight and or tread related
2012 F350SRW CCSB
post #7 of 16 Old 07-06-2013, 01:47 PM
897.3alltheway!'s Avatar
Quoted: 13 Post(s)
35's will bring down your mpg
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #8 of 16 Old 07-06-2013, 02:43 PM
The tires are too similar to cause that drastic of a change, it could be that your brakes are dragging.
What method are you using to hand calculate your mileage?
Karls03 is offline
post #9 of 16 Old 07-07-2013, 05:54 AM Thread Starter
I've checked just about everything brake wise. To calculate my MPG I use my GPS to track how many miles I've travleled. When I fill up I set my GPS to 0 miles then keep it on any time I'm driving, then when I fill up again I take the number of miles I traveled and divide it by the number of gallons the truck took.
I thought it was too similar of a tire size too but I took a look at the weight difference and I'm thinking more and more that its the weight that's killing me.
2012 F350SRW CCSB
post #10 of 16 Old 07-07-2013, 06:27 AM
The only thing that I could offer to your calculations is to do a couple of tanks filling until you can see the fuel in the neck. Yes this sounds anal, but it ensures that the same about was put in.
Other than that, I am at a complete loss as to why as well. As I stated earlier, I went from a 14.50 DOWN to a 12.50 and observed NO change in mpg. I thought for sure that I would have seen an increase due to the weight difference, but my truck proved me wrong.
Karls03 is offline
