Tire Loading Chart - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 06-30-2013, 12:15 PM Thread Starter
jesilvas's Avatar
Quoted: 3 Post(s)
Tire Loading Chart
I read on RV forums about tire loading charts, which show proper air pressure for a certain weight. I've searched but can't find those for LT tires.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #2 of 12 Old 06-30-2013, 02:00 PM
I'm not sure where you are going with this, but most tires have a load rating (D, E, etc) and/or a max weight for said tire. For example, the D rated 365 Toyos that I used to run were Load Range D, but had a higher max weight than the Load Range D 315 BFGs I replaced them with.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 12 Old 06-30-2013, 02:05 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1074 Post(s)
Feedback Score: 6 reviews
I don't think he is talking about the load rating for the tires, but rather what the actual desired psi for a certain loads weight is.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 12 Old 06-30-2013, 02:41 PM Thread Starter
jesilvas's Avatar
Quoted: 3 Post(s)
Correct.
Say for 3500lbs on an axle, that is, theoretically, 1750lbs on each tire. For a specific tire, the mfg says the tire should be at 55PSI for 1750lbs.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 12 Old 06-30-2013, 02:53 PM
That is correct, that's also a good example of why tires say MAX PSI on the sidewall. If you are trying to find the best psi for max tread wear, a piece of chalk works, but only on new tires. You run the chalk across the tire then see how it wears off for a given psi. On worn tires, all you're really doing is finding what psi supports why the center has less tread depth than the outer.
Karls03 is offline
post #6 of 12 Old 06-30-2013, 02:56 PM
ZMANN's Avatar
Quoted: 1781 Post(s)
Proper Tire Inflation
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 06-30-2013, 05:15 PM Thread Starter
jesilvas's Avatar
Quoted: 3 Post(s)
I understand how to check with chalk, done it before.
I'm wondering if there's charts for LT tires.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 12 Old 06-30-2013, 08:27 PM
Quoted: 393 Post(s)
Someone did a chart up over on TDS ages ago for a specific tire size. I haven't seen it since. you should be able to make your own though... if you have easy access to a scale, ballast, and a plethora of chalk & compressed air. Just load each axel in whatever increments you want up to the max GAWR and use the chalk method to find the appropriate pressures. Time consuming, but you'll know exactly what your truck needs.
Canadian Mind is offline
post #9 of 12 Old 07-01-2013, 05:31 AM
I think it's worth mentioning that wheel width plays a part in tread wear/psi requirements. For example, when I put my 285s on a 10" wheel, I got a better tread contact with more psi as compared to when they were on 8" wheels.
Karls03 is offline
post #10 of 12 Old 07-01-2013, 12:25 PM
town fair tire installed the wrong toyo mt on my truck.. now 7,000 miles later they are putting brand new set of 37's on my truck since the 35's are on nation back order for 90 days.. if i dont like the 37s theyll put the 35's what are the right weight load.
SO MAKE SURE YOU GUYS CHECK!!!!!!!! i called toyo direct and they called town fair to do it..
05 f250 harley edition
studded, deleted
icon shocks with 6in fabtech
sinister coolent filter
sct and ficm tuned
blue spring mod
powermax turbo
175cc
airaid intake
4in turbo back exhaust
black windows
busaandy is offline
