2004 wheel fitment - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 06-27-2013, 10:25 AM Thread Starter
2004 wheel fitment
Hey all, I'm looking into buying a set of used ballistic wheels they are 18x9 and the guy says they will fit a 99 and up superduty. Is this a correct statement as I have a 2004 f350 srw, I just want to be sure before I buy. Also he says they are a 5 1/2 offset. Does that sound right?
Thanks in advance
BobD981 is offline
post #2 of 7 Old 06-27-2013, 09:10 PM
BIG Laing's Avatar
Thanks in advance
99+ all has a 8x170 bolt pattern. But 99-04 has a 0 offset 8" wide wheel stock and 05+ has a +40 offset with a 8" wide wheel. They went to a wider axle with the coil suspension in 05+, so thats why the offset changed.
It sounds like he meant to say 5.5" Backspacing. I would post the offset/backspacing chart for you, but I am having technical problems... Google Image search "offset vs backspacing" and you should find a chart with 10x more info then you need.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 7 Old 06-27-2013, 09:11 PM
BIG Laing's Avatar
Karl, where are you? I can never remember B.S.ing required to clear the leafs on 99-04, and without my chart I am lost.
post #4 of 7 Old 06-28-2013, 03:03 AM Thread Starter
Ok thanks for the reply BIG, after looking at the chart it looks like the 5.5 backspace on the 9" wide rim will be a +12 offset, I would hope that clears, the guy says they were on his 01 7.3L so I guess they wouldn't rub as long as I don't go nuts with tire size. If anyone can shed a little more light on this before tonight when I go to pick them up Thatd be awesome! Thanks again
BobD981 is offline
post #5 of 7 Old 06-28-2013, 09:09 AM
Sorry, I was watching TV instead of patrolling the tire/wheel thread like I should have been.
I think 5" back spacing for a 99-04 is a little deep. If possible, test fit the wheels before committing to buy. The wheels will fit, sure, but the tires could contact the leafs at full steering arc.
For those who don't know, I have 10s with a 4.5" backspace (-25 offset). With 12.50s there's no issue, but the 14.50s that I had rubbed/limited steering SOME at full lock. Therefore I think your 5.5" backspace may not work.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 7 Old 06-28-2013, 11:26 AM Thread Starter
Thank you for the input Karl I think you just talked me out of them. I believe I'd be happier with -12 offset wheels so I can do a larger tire and fill out my bushwhacker flares.
Thanks again
BobD981 is offline
post #7 of 7 Old 06-28-2013, 11:37 AM
Refer to this chart when selecting wheels. What you should notice right away that while backspace is more or less independent of width, offset is all about width.
MaxWheelOffsetChartbyCodyGCarsonJPGThumbnail1jpg id 447019 | Motortopia
When selecting wheels for a 99-04, I'd stay with a backspace of 4.5" or less.
Karls03 is offline
