Tire size v. MPH - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 15 Old 06-23-2013, 06:40 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
Tire size v. MPH
Ok, since you guys are experts, tell me if I'm right.
Wifes truck, 2000 F150 Lariat.
Currently has P235 70 17. 63MPH on speedo means 60MPH real.
Door sticker says P275 60 17. That would be the same sidewall, which would be 63MPH speedo and 60MPH real correct?
Tire Size for 2000 Ford F-150 Lariat
Using that website, it gives me a list of possible OEM sizes.
Using the P265 70 17, I think I used the calculators right and it would actually correct my speedo, right?
General question, MY truck states 215 85 16 or something like that is OEM size. But using 235 85 16, my speedo is actually right. Is that common?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #2 of 15 Old 06-23-2013, 07:37 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
No your speedo is incorrect. The 60,70,85 etc is the percentage of the tire width. So for instance if you have 275/60r20's the sidewall is 60% as tall as the tire is wide. Make sense?
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 15 Old 06-23-2013, 07:43 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
No I understand that. I'm saying right now, on 235 70 17, it says 63MPH and is GPS rated right about 60MPH.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 15 Old 06-23-2013, 07:50 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Then your speedo needs recalibrated.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #5 of 15 Old 06-23-2013, 07:54 PM
Quoted: 770 Post(s)
X2
First number is in mm. Second is % of first. Conversion is divide by 25.4 to get inches, then double that plus rim.
So. Your door says correct tire size, specifically height, must be 30".
275.6=165 165/25.4=6.49 round up 6.5x2 13+rim17=30"
Whatever tire/wheel setup you want without recalibrating pcm to keep mph correct, just plug in the numbers to get as close to 30"
Corey@CNCFAB is offline
post #6 of 15 Old 06-23-2013, 07:55 PM
Wannabitawerm's Avatar
Maybe this will help. My stock tire size is 265/75r16. I have 315/75r16 and my speedo difference is 9.3% over my reading. There are charts on google that will tell you the percentage. You put in stick tire size and the other size and it will tell you over or under percentage. Can't find the link or I'd post it.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #7 of 15 Old 06-24-2013, 04:57 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
Speedometer Calibration / Tire Size Change Calculator
I used this and another.
From Tire Size for 2000 Ford F-150 Lariat <- that website, it lists three possible OEM sizes. 235 70 17 and 275 60 17 have the same sidewall size.
The other, 265 70 17 has a larger sidewall.
Basically, I'm making sure that if I run a larger sidewall, my speedo will drop in displayed speed.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 15 Old 06-24-2013, 07:02 PM
235 70 17 is 29.95" tall
275 60 17 is 29.99" tall
265 70 17 is 31.61" tall
In total, there is only a 5% difference between these tires. 31.61/29.99=1.05 Guess what? Your speedo is...wait for it.... 5% off 63/60=1.05. Everything is working like it is supposed to.
In short, your speedo was calibrated for the tallest of the three tires. Ford most likely did it because it's better to go slower than indicated than to go faster than indicated.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #9 of 15 Old 06-24-2013, 07:14 PM Thread Starter
jesilvas's Avatar
Quoted: 2 Post(s)
Ok cool, just wanted to make sure I thought it all through right.
That's so dumb, because my truck is also the same way.
215 85 16 = 182.75mm sidewall is sticker oem.
235 85 16 = 199.75mm sidewall is what makes speedo right.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 15 Old 06-24-2013, 07:24 PM
Keep in mind that different tire manufactures can have a different OD for the same size tire, hence why I'll never buy tires at Pep Boys ever again.
Karls03 is offline
