Mushy brakes 2000, F450 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 06-21-2013, 06:33 AM Thread Starter
Started noticing my brakes are getting mushy when I first start up my truck in the morning. When checking to see which headlight bulb was out, my brakes were really mushy this morning. My question to you is: what is the usual problem with mushy brakes and is it as simple as bleeding all wheels and changing fluid?
CKCRRanch is offline
post #2 of 3 Old 06-21-2013, 07:44 AM
HarvestingInternationally's Avatar
Could be...might have moisture in the fluid
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 3 Old 06-22-2013, 05:24 AM Thread Starter
mushy brakes
Thanks, I'll bleed the system and change fluid and see what the result is.
