e-brake keeps dragging - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 06-18-2013, 05:26 PM Thread Starter
How do I get the e-brake to quit dragging? I have rebuilt both sides, new disks, calipers, pads, e-brake shoes, new springs and other e-brake hardware, and on the side that drags the second (rear) cable. It does not drag all the time, but every now and again it will, and she gets HOT! I have the adjustment totally backed off, and in the shop it rotates without dragging (but of course). Any ideas of what to do or look for next??
It is an 2001 F350 Super Duty 4x4, single rear wheels.
JohnGreenlee is offline
post #2 of 4 Old 06-19-2013, 02:46 PM
JSchuricht's Avatar
I would replace the cable. It's probably corroded and not sliding back all the way.
JSchuricht is offline
post #3 of 4 Old 06-19-2013, 04:18 PM
c69ss396's Avatar
Also check for kinks, common on the T to axle cable
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 4 Old 06-19-2013, 05:38 PM Thread Starter
The front cable and the other rear cable seem to move quite freely, but I'll double check. Pulled the disk/drum off today and could see where the brake shoe was rubbing (not much) so filed it down a bit. Took it for a 20km drive and so far ok (but that means nothing, yesterday went 300km no problem, but on the return trip is when it got hot.
