Off set question. KMC rockstars - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 10 Old 06-06-2013, 10:25 AM Thread Starter
Hey,
Looking into getting 20" KMC RockStars
And running a 35" tires my truck is lifted 6 inches
What offset do I need. Looks like the options are ..+10 +35 +50
What exactly is the offset ?
Anything else to think about before the purchase ?
Thanks a lot Zach
2002 F-350 ext cab short box
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #2 of 10 Old 06-06-2013, 01:55 PM
Offset has to do with the relationship between the rim centerline and mounting flange. That being said, for best results, your desired wheel width is needed.
However, on pre 2005 trucks, a 10" wheel with a 4.25~4.5 backspace, or -25 offset, works fine.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 10 Old 06-06-2013, 06:35 PM Thread Starter
The tire size is going to be 35/12.5/20
Z-STROKE is offline
post #4 of 10 Old 06-06-2013, 07:01 PM
Yeah, kinda figured that, but your question can't be answered without a width. A -50 offset can be applied to every thing from a 5.5" wide rim on up. So, without a width, you're asking an incomplete question.
Karls03 is offline
post #5 of 10 Old 06-06-2013, 09:28 PM Thread Starter
Rim is 10" wide
Sorry I thought u meant tire width not rim width
Thanks Zach
Z-STROKE is offline
post #6 of 10 Old 06-06-2013, 09:33 PM
BIG Laing's Avatar
Like Karl said, you need a negative offset. None of the + offsets you posted will work.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #7 of 10 Old 06-06-2013, 09:37 PM
1999 - 2004 require no more than 4.25~4.5 backspace. Maybe this will help.
Name:	Offset backspace chart.jpg
Karls03 is offline
post #8 of 10 Old 06-06-2013, 10:10 PM Thread Starter
Still not completely understanding
I'm going to be running a 35/12.5/20 on a 20"x10" Rim
What's backspacing vs offset ?
Why are some # -25, -50 VS.. 4.00, 4.25
Thanks
Z-STROKE is offline
post #9 of 10 Old 06-07-2013, 06:33 AM
Offset relates to the centerline of the wheel, negative offset pushes the wheel away from the vehicle, positive pulls it in, and is measured in mm.
Backspace is the distance from the inboard wheel lip to the mounting flange, and is measured in inches.
For example, a 10 inch wheel with -25mm offset will have a 4.5" backspace.
Finally, inches/25.4=mm.
Karls03 is offline
post #10 of 10 Old 06-07-2013, 01:46 PM Thread Starter
Thanks for the help guy's
Z-STROKE is offline
