Tire and Height issue - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 05-30-2013, 07:01 PM Thread Starter
Randonizer's Avatar
Ok so currently I have 285.75R16 on my truck now. I have a 2in RC leveling kit on it. I want to upgrade to 20x12 Fuel Octanes and 35x12.50 tires. First off, will it fit? I have seen many guys with 35s and leveling kit so i sure it will. I figure it will rub a lot. Second, I park in a parking garage. Right now I'd say I clear it by at most 4in. If I got 35s how much would it increase my height? Im thinking about an inch, maybe two. I probably sound stupid but thought I'd ask you guys first.
This is how my truck sits now.
2001 F250
TS Performance 6 Position Chip
AFE Power Cold Air Intake
Diamond Eye Exhaust
Pillar Gauges
Randonizer is offline
post #2 of 6 Old 06-07-2013, 05:12 AM
Redlazer's Avatar
The answer to the first question is yes they will fit. And to the second is you will only make your truck 1in taller with 35 in tires. The 285x75r16 tires are 33in tires so going to 35s will only make you 1in taller bc one inch of the tire would be on the bottom and one Inch would be on top. They should also not rub.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #3 of 6 Old 06-07-2013, 06:08 AM
Depending on backspace, those 12s will put those 35s into the bumper or trailing edge of wheel opening. I can contact my fenders (well not so much after the hammer mod) simply rolling into a parking lot from the street, and I'm on a 4 inch lift. 2" less lift, 2" more rim, yeah, I see contact.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 6 Old 06-07-2013, 06:14 AM
asian195's Avatar
Quoted: 2 Post(s)
I've got 20x10 with 35s and leveling kit. I rub while turning and hitting a bump. I have even pulled my inner fender back some. If your gonna run 12" wide wheels, it's gonna rub A LOT... if you want 12" wheels, if recommend a 4" lift also. Stick with 10" wheels, it still look good...
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
ARP Head Studs
To Do/Wish list:
FICM tune
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #5 of 6 Old 06-07-2013, 06:31 AM Thread Starter
Randonizer's Avatar
Thanks for the replies guys. I just bought a 6.5" lift instead. I'm going the oppisite route. Do you guys know if there will be any rubbing if I put 35s or 37s on my stock 16x7s?
2001 F250
Diamond Eye Exhaust
Pillar Gauges
post #6 of 6 Old 06-07-2013, 09:29 AM
Wow, dude! You sure did do an about face. Personally, I think both tires are too wide to put on that wheel. The 35 should be on a 10 and the 37 would work best on a 12 (a 10 would work, but wouldn't be my first choice).
IMO, the wheels should be close to the tread width. When this is achieved, you can run more psi with max tread contact. I ran 14.50s on a 10 inch wheel and they went bald in the center while having deep tread on the shoulders. I run my 315s at 40 psi on 10s to get even tread wear.
Karls03 is offline
