Dick Cepek FCII split side wall. - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 05-29-2013, 12:51 PM Thread Starter
ZIKA's Avatar
So my FCII's have about 35,000 miles on them and I was looking to milk them through the end of summer. Well that all changed today. While driving at low speed I could hear a rotational rubbing noise. My side lugs on the tires have been showing signs of dry rot around each lug and one finally let go. It would leak every rotation when on the bottom and the tire would buldge. What chaps my *** is these are only two years old.
What really sucks is the FCII's are no longer made and are replaced by the Fun Country's which are not available for a couple weeks in a 37/12.5/17. The tires that I really wanted was a Procomp Xtreme All Terain but that is not available untill August. Sucks!! Because I needed my truck, I went with a Nitto Trail Grappler. I know one person who has them on a dodge and he said that they wear like iron. My worry is that they are going to suck for tug a truck and be to aggressive for sled pulling. This was the only tire that I could get by this Friday. Blows!!!!
ID:	117937   Click image for larger version
ID:	117945   Click image for larger version
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #2 of 3 Old 05-29-2013, 01:28 PM
Eric@PTP's Avatar
I had a set of these in 38/15.50/20 a few years back, they lasted over two years and still had about 1/4" tread on them before they started dry rotting and cracking. Check the date that they were made, should be on the side wall somewhere. Most people don't know tires have a shelf life, and I've seen tires as old as 6 years still being sold out there. They may be new and unused unmounted but they will still dry rot in short time due to age.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #3 of 3 Old 05-29-2013, 02:04 PM Thread Starter
ZIKA's Avatar
I am willing to bet that you are correct. Our explorer has six year old tires on it with no problem and here these are dry rotting away in 2 years. I think that a typical tire is only good for about 5-6 years.
ZIKA is offline
