Pad shapped marks on rotors - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 05-27-2013, 08:41 AM Thread Starter
What causes the pad shaped marks on the rotors? It looks just like the edge profile of the pad. Is this caused by heat? Dirt? or what? You can feel the marks with your fingers and it will grab the rotors and give the pulse feeling in the steering wheel. Is there a way to remove it and prevent it?
Sold the 6.0 for a 2015 6.7
MBRP 4" turbo back,
Accufab intake elbow,
SCT w/DP Tuner tunes,
RCD EGR delete,
EGT, boost, trans temp, fuel pressure gauges and scan gauge II
ARP studs,
Black Onyx head gaskets - they are gone and back to stock
6.4 banjo bolts
Crossover line
Dieselsite coolant filter
upgraded fuel regulator and other ford upgrades
Western MVP Plus plow
Snow ex salter
Jeckstine is offline
post #2 of 5 Old 05-27-2013, 11:43 AM
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Stuck caliper possibly
You could have a stuck caliper that is not releasing completely and caused the pads to wear down the rotor. As for the pulsation the rotor is warped and needs to be replaced. Ive tried to turn them before and they just warp again very quickly. Sorry to be the bearer of bad news
jim
jimhuntertx is offline
post #3 of 5 Old 05-27-2013, 11:51 AM Thread Starter
Pads were new about 11 months ago and still look new. If you scape at it it comes off. Almost like the pad got burnt or melted to the rotor. Rotors may be warped but turning it by had it grabs right where the marks are.
MBRP 4" turbo back,
RCD EGR delete,
ARP studs,
6.4 banjo bolts
Crossover line
Snow ex salter
post #4 of 5 Old 05-27-2013, 11:58 AM
ZMANN's Avatar
Quoted: 1348 Post(s)
I am surprised it has lasted after you applied the brakes ?
you can clean the rotor and lightly sand them to see if it returns
We Miss you Ronnie
ZMANN is offline
post #5 of 5 Old 05-27-2013, 12:16 PM Thread Starter
I thought about that. Was just trying to figure out what it actually was.
MBRP 4" turbo back,
RCD EGR delete,
ARP studs,
6.4 banjo bolts
Crossover line
Snow ex salter
