Max Size 2wd Tire Question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 05-21-2013, 01:50 PM Thread Starter
Boostin10's Avatar
Ok guys, I have tried searching for this but it seems I can not find what I am looking for. I am looking at getting a set of +18 offset 20x9 rims and was wondering if anyone knows what the max tire size I could run without scrubbing would be? I was thinking a 305/55/20 but it seems like it might be tight. Ohh yea the truck it would be going on is a 2wd 2010 F250. Thanks in advance for any insight you have to offer.
Boostin10 is offline
post #2 of 7 Old 05-22-2013, 01:47 PM
Discount Tire's Avatar
Quoted: 9 Post(s)
What is the stock tire and wheel size that came on your vehicle.
Low Prices! More Choices! FREE Shipping!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
Discount Tire is offline
post #3 of 7 Old 05-23-2013, 04:52 PM Thread Starter
Boostin10's Avatar
Truck came stock with 17s and now has 265/70 tires on it.
2010 F250 PSD Reg Cab
-Spartan tuner, MBRP cold side, DE Turbo-Back, AFE CAI, Sinister Diesel Elbow/Delete.
HP=Not Enough
post #4 of 7 Old 05-23-2013, 06:19 PM
My truck is an 08 2wd. I do have a leveling kit on front and the tires are 285/70/17.
That translates to about a 32.5 to 33 inch tire.
75cj5 is offline
post #5 of 7 Old 05-23-2013, 06:22 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
The biggest it can be is 33".
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #6 of 7 Old 05-24-2013, 09:28 AM
Quoted: 9 Post(s)
Thank you for the additional information.
According to our fitment information, an 18x9 +18 mounted with 305/55-20 tires will sit about 1.75" to 2" further out when compared to where you factory set up sits now so you'll probably have some slight tire rub at full lock. A little trimming should easily stop this. If you want to avoid tire rub all together then tire size 285/55-20 is the way to go.
At The Store:
To Your Door:
Useful Links:
post #7 of 7 Old 06-02-2013, 02:42 PM Thread Starter
Boostin10's Avatar
Ok so I think I have decided I am going to go with the 305/55r20 Nitto Dura Grappler. Does anyone have an experience with this tire? From the looks of the Nitto site it has a 60k mile treadwear warranty on it so it must not be too bad. Thanks in advance for any insight anyone can provide.
HP=Not Enough
