wheel and offset question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 05-19-2013, 01:06 PM Thread Starter
aaron89's Avatar
hey, have a question about wheels and offset, searched forever but cant really get a clear answer on what i want or need. I currently have roughly 8' of lift (6'' 4 link kit from rough country and 2 leveling kit) im wanting to go with a 38x13.50x20 tire/wheel combo but not sure on what to get with back spacing and offset. Also not sure if i should go with a 9'' wheel or a 10. any advice would be greatly appreaciated. truck is a 07 btw. thanks.
07 Lariat Outlaw
8'' rough country lift
egr delete / updatded oil cooler / hpop fitting
coolant filter
blue spring upgrade
custom sniper tune
5'' diamand eye exhaust
recon cab lights / HID 8000k headlights/ fogs
aaron89 is offline
post #2 of 12 Old 05-19-2013, 03:41 PM
38s work with 8" of lift.
With a 13.50 tire, I wouldn't mount it on anything LESS than a 20x12. A -12 off set will maintain the OEM backspace, a -51 will give you about a 4.5" backspace, as in push the tires out farther. I have 38x13.50s on 10s on our half ton, I have to run 25 psi to get anymore than the center tread on the road.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 12 Old 05-20-2013, 01:16 PM Thread Starter
aaron89's Avatar
so a -25 off set would i rub do you think
07 Lariat Outlaw
coolant filter
blue spring upgrade
custom sniper tune
aaron89 is offline
post #4 of 12 Old 05-20-2013, 01:29 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
You should definitely stay with 4.5" of backspacing regardless of the wheel width for a lifted superduty. If you stay in that backspacing, the extra width on your wheel will all be on the outside.
-12 in a 9"
-24 in a 10"
and most manufacturers will make a -44 in the 12"'s, that is actually 4.75" of backspacing, but will work just fine if you can't find a wheel in -51mm.
As far as the width goes, a lot of it is personal prefference on how you like the wheel/tire to look. Manufacturers have reccomended widths and lots of people have opinions on it too, but do what you like the look of.
I had Toyo 12.50's (actually 13.5 wide) on 9" and got 70,000 miles on them @60psi. To me 9" looks a little too narrow for a 12.50-13.50, but mine lasted great. I think 10" wide wheel is the perfect size for that tire. That is what i'm running now, I like that look much better. Every time one of my customers comes in and gets 13.50's on a 12" wheel, I just don't like the look of it.....too wide for the tire IMHO.
Most of that is my opinion, but I hope some of that helps
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
post #5 of 12 Old 05-20-2013, 01:34 PM
Let's go B's!!!!
Southpaw's Avatar
Shouldn't on on a coil spring truck....
Chris
Southpaw is offline
post #6 of 12 Old 05-20-2013, 04:06 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
for what its worth, i ran 12.6" wide tires on a 9" wide rim on my 05 and run the same tire on my 2010 with a 10" wide rim now and road manners are definitely better and wearing much better. so go as wide as you can especially with a 13.5" wide tire i would atleast get a 10" wide rim. good luck
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 12 Old 05-22-2013, 07:32 AM
It depends on the width, -25 offset will have different backspacing as width changes. If you are considering a 10" wheel with a -25 offset and a 13.50 wide tire, then you're probably going to end up trimming the spoiler under the front bumper.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karls03 is offline
post #8 of 12 Old 05-22-2013, 02:15 PM Thread Starter
aaron89's Avatar
wouldnt mind a bit of trimming, think im going with XD monsters in a 20x10 and runnung 38x13.5 toyos, anyone have any pros or cons with either of these. thanks.
07 Lariat Outlaw
coolant filter
blue spring upgrade
custom sniper tune
aaron89 is offline
post #9 of 12 Old 05-22-2013, 02:44 PM
Like I said earlier, I wouldn't mount a 13.50 tire on a 10 inch wheel. If you use a 12" wheel, then you can run a higher psi without riding on the center of the tread. A higher psi means less rolling resistance which means not as much of an mpg loss rolling 38s.
Karls03 is offline
post #10 of 12 Old 05-23-2013, 06:18 PM
psi_2_high's Avatar
i just ordered my 7" lift for my 2011 and ive been told numerous times by many members, that i will be fine running 20xp BMF Novacianes on a Toyo M/T 38/13.50/20.????? am i missing something here??
2011 F350 FX4, Lariat, Recon Lights, more to come!!
2005 F250 ,Garret PowerMaxx, Studded, Bulletproof EGR Delete, 12" Rize quad link / King Coils / King Ress shocks, 4.56 Gears, Full HD interior, Straight Piped, Toyo 40/15.50/22 Fuel Hostage Deep Rim. And a ton more stuff i forgot!!
psi_2_high is offline
