Pressure Question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 2 Old 05-19-2013, 07:53 AM Thread Starter
ymraspc's Avatar
Send a message via Yahoo to ymraspc
Pressure Question
I am running 35x12.50R18 Toyo OpenCountry MTs with 60 psi in them. Is this too much? I also have noticed my mpgs have gone down a bit from running the higher pressure. I had only 35psi in them before, but I think that just wasnt enough. Any thoughts?
Wifes ride 2006 Crew Cab F350
With Rancho Lift Kit and 35X12.50R18 Toyo Open Country MTs
'01 2500 White,EC, LWB, 272k...HX40 Turbo, DD-2 injectors, BHAF, Holley Black Label Fuel Pump, Vulcan Big Line Kit, Suncoast Valvebody, 4" exhaust, egt gauge, boost gauge, trans temp gauge on pillar mount, fuel press gauge, TST PowerMax3, Silencer Ring MIA
Sold to move to England in 2010
ymraspc is offline
post #2 of 2 Old 05-19-2013, 09:44 AM
That your mpg went down from higher psi is the opposite of what's supposed to happen. Higher psi, to a certain degree, reduces rolling resistance and will also make you ride on less of the tread, depending on wheel width. A 12.5" wide tire on an 8" wheel at 60 psi is going to go bald in the center and have deeper tread on the outsides.
To find optimum tire wear, run chalk across the tread and adjust the psi to until it all scrubs off. I would start at max psi, then reduce psi until the chalk mark is scrubbed off. However, this only works on NEW tires. Older tires will have a flat surface to the road, but tread depth across the tire can vary. I run 315-75-16s on a 10 inch wheel and 40~45 psi is my optimum psi for best tread wear.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
