Question on 17" ford wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 05-17-2013, 04:30 AM Thread Starter
I have a n 03 f250 4x4 with the 16" wheels. I acquired a slightly used set of 285/75/17lt tires. I have going back and forth on what type of rims I should get. There is a guy local that has a set of 17" ford wheels off of and 05 or 06 truck. My question is, will I need spacers for 17's and 285's?
03superstroke is offline
post #2 of 8 Old 05-17-2013, 10:48 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, you will need spacers for the 17" factory wheels!
The fronts won't even go on all the way because they will hit the tie rod ends, I have my stock 17" wheels and tried them myself on a pre-05 Superduty and found that out.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 8 Old 05-17-2013, 04:05 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
yep i ran into the same issue. i knew i needed spacers beforehand but i put them on to see and they are way sucked in. can turn about 6 inches before it rubs on the tie rod ends lol
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 8 Old 05-19-2013, 10:51 AM
1999-2004 models use a 4.25"~4.5" backspace where 2005 and up use about a 6.25"~6.5" backspace. I would drop the money on some aftermarket 17X10s for proper fit, a set of GOOD spacers are going to cost almost as much as NEW wheels. Yes 17x10, when I ran 285s on a 10" wheel I was able to run a higher psi with a better tread contact patch than on 8" wheels without ballooning the sidewalls out.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 8 Old 05-19-2013, 06:05 PM Thread Starter
Thanks for the info. Do you have any idea of the offset needed for the aftermarket wheels? I have about 45,000 miles on my current tires. By the end of the Summer I'm gonna be replacing ball joints, shocks, etc. I think I'm going to put a rough country 2.5 leveling kit on the front and a extra leaf on the back. Wheels and tires will be following that. I want to replace the ball joints before I put new tires on. Like I mentioned before I have a set of lt285/75/17's that will last me a good year of so. Hopefully I can start gathering the parts in the next couple months and when my current tires are done I can do it all at once. By then I'll have close to 60,000 miles on my nitto terra grapplers. Not bad for a slightly used $400 set of tires off of craigslist.
post #6 of 8 Old 05-19-2013, 06:31 PM
I run -25 offset/4.5 backspace 10s on my 2003
Karls03 is offline
post #7 of 8 Old 05-19-2013, 07:44 PM Thread Starter
Could I trouble you for a picture? If not, how far do they stick out?
post #8 of 8 Old 05-19-2013, 07:50 PM
Look in my profile, I have head on shots of my 315s on 10s. 285s will be " closer to the sheetmetal. It's been a few years since I ran 285s.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karls03 is offline
