Rear Brake Assembly Bolt Torques - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 05-16-2013, 06:37 AM Thread Starter
2002 F350 SD, DRW. Need the following torque specs for the rear brakes please:
Rotor to hub bolts-
Axle flange to hub bolts-
Caliper mounting bracket bolts-
Caliper to mounting bracket bolts-
Thanks for the help.
White Dually is offline
post #2 of 3 Old 05-19-2015, 09:21 AM
Looking for the same specs for my 2005.
05 CC DRW
4" t/b Magnaflow
Edge Evolution
nhra6002 is offline
post #3 of 3 Old 05-20-2015, 09:21 AM
Soledad's Avatar
Garage
This is what I found for my 2006. I figure the 2005 would be the same but not sure on a 2002.
Edit: Awe crap, I just re-read and see you have a DRW. Don't know if these would apply to a DRW or not.
Front Disc Brake
Caliper bolts (F250, F350): *76Nm - 56 ft lb.
Caliper flow bolt w/crush washer: *47Nm - 35 ft lb.
Caliper anchor plate bolts (F250, F350): *225Nm - 166 ft lb.
Wheel hub extender nuts: *176Nm - 130 ft lb.
Brake disc shield screws: *11Nm - 8 ft lb.
Rear Disc Brake
Brake caliper bolts (F-250, F-350) single rear wheel: *35Nm - 26 ft lb.
Caliper flow bolt: *35Nm - 26 ft lb.
Caliper support bolts: *137Nm - 101 ft lb.
Disc-to-hub bolts: *121Nm - 89 ft lb.
Caliper anchor plate bolts (F-250, F-350) single rear wheel: *275Nm - 203 ft. lbs.
Wheels and Tires
Spare tire carrier bolts: *20Nm - 15 ft lb.
8-Lug M14 wheel bolts (F250/350): *224Nm - 165 ft lb.
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
