Wheel offset help - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 05-16-2013, 06:19 AM Thread Starter
Wheel offset help
I have a stock 2008 f250 CC. I am looking at 20x9. My tires are 285/65. I need to see what offset is best 0 or -18? I don't really want them sticking out, but I also don't want an rubbing. Should I look for a wheel with a positive offset??
Randy181421 is offline
post #2 of 7 Old 05-16-2013, 06:53 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Look for as close to stock back space as possible..6"
CT Performance, Inc. is offline
post #3 of 7 Old 05-16-2013, 08:58 AM
A +25 offset will give you a 6 inch back space on a 9 inch wheel. A +32 will give you a 6.25 inch back space. If the stock back space is 6 inches, then +25 is where you want to be.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 7 Old 05-16-2013, 12:35 PM
Discount Tire's Avatar
Quoted: 9 Post(s)
A 20x9 with a 0mm offset will stick out about 3/4" beyond your fenders. A 9" wide wheel with a -18mm offset will stick out about 1.5" beyond your fenders.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
post #5 of 7 Old 05-16-2013, 12:53 PM
Are you sure about that? A 0 offset would be a 5" back space and a -18 would be about 4.25" backspace. The OP said he has an 08 and if I'm not mistaken, the OEM backspace for an 08 is closer to 6". Based on that, a one inch wider wheel (OEM 8 to after market 9) and a an inch less of backspace is going to move the rim lip out 2 inches or 2 inches depending on what the OEM backspace is.
Karls03 is offline
post #6 of 7 Old 05-16-2013, 02:16 PM
Quoted: 9 Post(s)
My estimations are in reference to the fenders edge, not from where the OE wheel sits.
At The Store:
To Your Door:
Useful Links:
post #7 of 7 Old 05-18-2013, 11:04 PM
BIG Laing's Avatar
Well the stock wheels are only sucked in 1/2" from the fenders... So your first post is quite a bit off.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
