Rubbing help - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 05-11-2013, 01:00 PM Thread Starter
Redlazer's Avatar
Question Rubbing help
My dad has a 2000 f250 SD. He has 285x75r16 on oem wheels. When he turns hard to the right the passanger front tire rubs just barely on the rear part of the springs. What can be done to correct this? What has me confused is the driver side front tire doesn't rub at all.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 3 Old 05-11-2013, 01:05 PM
Has he ever checked to see if his axle is centered? I don't think 285s on stock wheels should rub the leaf spring at all.
1994 Chevrolet Caprice Wagon LT1
1995 Ford F150 Flare Side 4x4
2008 Honda CR-V
Backwoods Electric is offline
post #3 of 3 Old 05-11-2013, 01:08 PM Thread Starter
Redlazer's Avatar
Not sure ill tell him to have it checked. Any other ideas?
CAROLINA GRAY BOY
Redlazer is offline
