Rim/Tire advice? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 05-07-2013, 06:56 PM Thread Starter
tony97gt's Avatar
Rim/Tire advice?
Ok so I suck with the math and schematics of rim and tire combos so I'm turning to the community for help. I need new tires so I've decided to upgrade the rims as well. I love the look of the XD Monsters in black, and I'm guessing I should go with 20" because my stocks are 20" now (Harley Davidson). I don't run my truck in the mud but I love the rough mud tire look so I'm willing to sacrifice a little road noise for the look. I have, but haven't installed yet, a bilstein 2.5" level kit that I'm waiting to install with the new rim/tire package.
I don't know if I should go with 35's or 37's, and what the advantage/disadvantage of either one is. I do hot rod my truck a little bit here and there so I'm guessing the 37's would put more stress on the tranny? I don't plan on doing a lift kit since they are pretty pricey. Just want the truck to sit a bit taller and want the mud tire look. I only tow an 18' boat for now, and carry an atv in the bed now and then, so no heavy hauling. Also, what rim size would be best as far as backspacing or offset? I want the rim/tire to stick out about an inch from the wheel well, but not so far that I sling rocks and dirt down the side of the truck every day. I was also thinking of purchasing the bilsteins for the rear and a steering stabilizer kit if needed.
Thanks in advance.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #2 of 4 Old 05-07-2013, 10:40 PM
BIG Laing's Avatar
With just a leveling kit stick with 35" tires. IMO 37" is a little to "stuffed". And yes 37" will cause more wear and tear then 35's.
I am guessing the wheels are 9" wide? If so you can run anywhere from a +25 offset to a 0 offset and clear everything, assuming your going with 12.5" wide tires. +25 would have them sucked in the most, without rubbing the radius arm. 0 offset will stick them out a bit, for that stocky look. I know some guys on here running -12 offset on 9" wide rims, that say they don't rub the fenders... I beleive you would rub your fenders pretty bad if you were offroading with that setup.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 4 Old 05-08-2013, 03:00 AM
Gapowerstroke's Avatar
Thanks in advance.
I just installed a 2.5" lift with 35x12.5 toyo mts on 18x9 wheels with 0offset and 5" bs. They rub inner plastic fendet liner pretty bad when I turn and barely miss lower rear outer fender. Hope that helps.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #4 of 4 Old 05-12-2013, 07:30 AM
Quoted: 47 Post(s)
My setup only rubbed the felt liner so I trimmed it.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, Westin Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
