wheel offset - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 13 Old 05-03-2013, 06:58 PM Thread Starter
madox1992's Avatar
wheel offset
I am not for sure what would look best on my 08 power stroke. I am looking at either -12 offset or -25. I want the wheels to stick out just a little bit from the fender well but not very far. Just wanted to see if anybody had any recommendations on what they think, or a picture of their truck for me to look at with those offsets. Thanks!
madox1992 is offline
post #2 of 13 Old 05-03-2013, 10:17 PM
Off set changes with width, therefore, without knowing the width, your question can't be accurately answered.
Back space, on the other hand, doesn't change with width.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 13 Old 05-04-2013, 06:48 AM
Gapowerstroke's Avatar
I've been on this subject for weeks now and here is what I have learned.Depending on size of tires and lift will dictate how much backspacing you can run, I ran in to this when ordering my wheels. I knew the ones I wanted when I panned everything then I opted for a leveling system instead of a 4.5" lift. When I went to order wheels and tires I found out the wheels I want only come in a 4.5" bs (-12 offset). Without trimming I would rub with 35's so I chose another wheel with a 5"bs(0 offset).
I believe your stock wheel is like mine and is an 8" wide wheel with likely a 6" backspacing. If I understand it correctly and you stayed with an 8" wheel but switched to a 5" bs then it would move the wheel and tire out 1". By going to a 9" wheel I believe that would add another 1" to the outside.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #4 of 13 Old 05-04-2013, 07:49 AM
A -12 offset applies to everything from a 6.5" wide wheel to a 15" wheel wheel. A -25 applies to a 7.5" to 15" wide wheel. So, without knowing what width you are looking at, giving an accurate answer is impossible.
Big LAING originally posted this chart a few weeks ago and I found it VERY helpful.
Karls03 is offline
post #5 of 13 Old 05-04-2013, 08:40 AM
Thanks for that chart. I did forget to mention Those numbers only applied to my wheel choice of 9" width
post #6 of 13 Old 05-04-2013, 09:02 AM
The 05 and up need about a 6" backspace, given the listed choices for a 9 inch rim, I think the -12 offset would have the results that you are looking for. The -25 may push them out farther than you want.
Karls03 is offline
post #7 of 13 Old 05-04-2013, 09:08 AM
I wanted to go with the -12 but because I went with the level kit I would have had to trim some based on advice from a few people with more experience than I have. So I decided on the 0 offset (5"bs). It may still be tight.
post #8 of 13 Old 05-04-2013, 09:14 AM
A 33 should work without issue, I don't know about a 35. When I went 35s, I put on a 4" lift at the same time.
Karls03 is offline
post #9 of 13 Old 05-04-2013, 12:24 PM
DoubleDpsd's Avatar
-12 on my 9.5" wide 20's on a level kit and have to try to get it to rub with a 33" a/t.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #10 of 13 Old 05-04-2013, 02:51 PM
BIG Laing's Avatar
Looks like you have already covered this thread Karl. I just stole the offset thing from Google images...
How wide are your tires? Those should be rubbing the leafs near full lock on 04 and older super duties. On 05+ trucks that wheel width and offset would be perfect IMO.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
Tags
offset , tires , wheels
