Nitto Trail Grappler M/T tire pressure - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 05-02-2013, 09:40 AM Thread Starter
tonsofduty's Avatar
So I have a set of Nitto Trail Grappler M/T (295-55-20) mounted on the stock king ranch wheels. The door plate says 65 front 80 rear. What do you guys run with an unloaded SRW F350?? 80 seems a bit much unloaded. Thanks
tonsofduty is offline
post #2 of 5 Old 05-02-2013, 09:48 AM
JER-1's Avatar
Quoted: 17 Post(s)
My dually sticker says 75 front 65 rear i have 75 front and 70 rear
Jer-2
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #3 of 5 Old 05-02-2013, 11:23 AM
Blue Goose's Avatar
You need to go by the tire rating verses the door label unless they match. When I got my new Toyo m/t's the shop had them set at 80 front and back and I thought I was going to wreck at any moment over 35mph so I kept dropping the pressure till it drove right unloaded and then I checked it loaded and settled on 45psi all the way around. But thats just me.
06 KR 250
Blue Goose is offline
post #4 of 5 Old 05-02-2013, 06:06 PM
JER-1's Avatar
Quoted: 17 Post(s)
I've went buy tire PSI rating all my life, till these new nitto dura grappers at 80 lbs. per tire whats on them, they will not sit correct and run correct thats so much air, and 10 plys that the rear tires only the middle would touch the road the outside inch or so of each tire was not even wearing, thats why the door sticker calls for 60 psi in the rears not enough weight to sit the tires proper.The door sticker calls for 75 in the front due to motor weight , at 80 psi were not sitting correct I,ve found happy spot of 75 psi in the front seen to be wearing correctly now. 68 to 72 psi in my rears.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
ZOODA MOD
KITTY RAN OFF
SINISTER EGR DELETE
OIL COOLER REBUILD
BLUE SPRING UPGRADE
JER-1 is offline
post #5 of 5 Old 05-03-2013, 05:24 AM
Set thm t 35-38psi. They state not to exceed 40 PSI to set bead so they need lower PSI than that. I run mine at 35, and they have worn fine.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
