Cracked wheel - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 04-30-2013, 08:55 AM Thread Starter
Blazin8556's Avatar
Cracked wheel
Was trying to take the wheels of the front of my truck. But my half inch impact won't do it. While I was waiting on my compressor to catch up I noticed about a half inch crack in one of the holes on my passenger side front wheel. Would you guys trust a repair shop or buy a new rim.. Next question where can I find info to update my wheels to the sd star style wheels or what do I type for searching. I ran a quick search but came up with nothing of use. Just jibber jabber. If im not mistaken they are different lug patterns right?
My current ones are the obs ford dually aluminum. In avatar pic.
Thanks
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #2 of 3 Old 04-30-2013, 10:11 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes the 99-04 were 8x170mm then 05+ i believe they went to 8x200mm. So you would need to change the front dually spacers into adapter/spacers going from 8x6.5 to 8x170 or 200 depending the year of wheels you buy. For the back you would need adapters to the new bolt pattern.
Just make sure you buy high quality spacers because these trucks are big and carry big loads so spacers and adapters can be dangerous. Its honestly safer(and probably cheaper) to buy aftermarket rims that fit your bolt pattern than buying all those sets of spacers and adaptors AND the new SD wheels. But thats my opinion so take it with a grain of salt.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 3 Old 04-30-2013, 01:28 PM Thread Starter
Blazin8556's Avatar
Thank you for the info. I dont trust spacers much anyhow. Guess ill run a spare steelie for while. Get some aftermerket or a replacement. Or may have this ond fixed? I didnt think about the $$ involved till you said something. So thank you for that.
