06 F350 park brake backing plate rusted out? pics - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 04-29-2013, 06:29 AM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 4 Post(s)
Garage
See the picture... truck hasnt had the parking brake in it for over a year. It was removed when a part was lost on the road one trip, ordered the new park brake kit shortly after. went to install it the other day finally and this is what i find!
Can this backing plate be bought from ford new? Looksl ike its held on by the huge bolts that hold the hub onto the axle.
Name:	backing plate.jpg
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 3 Old 04-30-2013, 07:00 AM
Common, you don't need any of that stuff, but if you do replace it, RockAuto is way cheaper than anywhere else. I had my mechanic just leave that stuff off, and just didn't have an ebrake.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #3 of 3 Old 06-05-2013, 06:15 AM
Hello, I was just doing this job on my 2003, f350 w/ 110k miles over the weekend. I got the backing plate at a local parts store. I had the pins and keepers for the brakes get inside the drum and reak havoc when the right side rusted through. The plates were $65 for a set. I know of this happening on other fords and guys have left the parts off but i wanted mine fixed. Once the hub is off like you have pictured, most of the work is done. Remove the remaining 4 nuts and give the bolts a firm smack with a hammer. Removing the plate also requires a little help from a chisel of screw driver.Tightening the hub nut was also a concern of mine. I read in other places (on this site) the torque is 60ft pounds while turning the hub then loosen 7 clicks. 80ft lb on the axle bolts.
Name:	back plate.jpg
IndianaJoe is offline
