Let's play name this wheel? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 18 Old 04-22-2013, 06:37 AM Thread Starter
OrangeBlood's Avatar
I am trying to find some center caps for these wheels and a possible replacement wheel (see chip on lip in pic)? I've pulled all letters and #'s off the wheels and no luck? It does have made in China stamped very clearly on them other than that notta? I figured I would throw them up here to get your opinions as I know a lot of us here have one. If you can see the chunk or chip on the rim lip, upper left in pic, should I be concerned with this and replace? I appreciate any info or advice from the great folks here!
[IMG][/IMG]
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
37x13.50x22 Nitto Trail Grapplers
SCT tunes from Innovative Diesel
and some other stuff a work in progres blahblahblah
OrangeBlood is offline
post #2 of 18 Old 04-22-2013, 10:26 PM
Blazin8556's Avatar
Have you tried any of your local custom wheel shops?
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
post #3 of 18 Old 04-23-2013, 04:39 AM Thread Starter
I've tried a couple, they act like I am just wasting their time? As soon as I can find one to help me out I just may buy my tires from them (if they can get 37's) a lot of shops here said they would not even mount the 37's or balance them? I may need to go to a big rig shop and order tires online?
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
post #4 of 18 Old 04-23-2013, 06:28 AM
The Maddawg
maddawg89's Avatar
Quoted: 290 Post(s)
Feedback Score: 3 reviews
I'm not sure but they sure are nice!
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #5 of 18 Old 04-23-2013, 06:34 AM Thread Starter
Thanks maddawg, I like them too! I just hope I can find center caps for them?
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
post #6 of 18 Old 04-23-2013, 06:37 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
if you have a 4 wheel parts in your area I'd check with them...thats the only reason I go to them only ones here too that'll touch anything over a 33
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 18 Old 04-23-2013, 11:05 AM Thread Starter
I don't think there is a 4 wheel parts anywhere close, we do have a Harmon offroad suspension close" I will check with them to see if they even mount and balance tires at all? Thanks dannaw!
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
post #8 of 18 Old 04-23-2013, 11:09 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
back when I had my jeep they did a warrenty on my set that came off another truck (4 Wheel Parts) but anywho...the wheel should have some type of numbers stamped on the inside or it...also most wheels have a sticker on the part under the tires if that makes sence so have one or two dismounted and try that too.
dannanw is offline
post #9 of 18 Old 04-23-2013, 06:13 PM Thread Starter
I may do that, Thanks dannaws!
b
2005 CCSB F-250 FX4
6" lift
22x12 Fuel Hostage
post #10 of 18 Old 04-23-2013, 08:50 PM
10 bucks says they are KMC wheels
MonsterBilly is offline
Tags
20x10 , wheels rims
