tires for better fuel economy - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 04-20-2013, 08:15 AM Thread Starter
Redlazer's Avatar
I'm going to be getting 18in wheels in the near future. I'm looking to get better fuel economy when changing my tires. I'm looking at 275x60Rx18s or 285x65rx18s Nitto terra grapplers. Which tire size should give me better fuel economy?
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #2 of 8 Old 04-20-2013, 08:19 AM
majek5's Avatar
The 275 will be lighter, therefore, better mileage. How noticable...probably not much. Get the 285, they will look better!
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #3 of 8 Old 04-20-2013, 08:20 AM
ctrow89's Avatar
Your 275s will give you sightly better bc there is less friction involved and a slightly smaller tire meaning less weight. Now, how much will it make a difference? Being that they are that little of difference (.5" wider and 1" in diameter) it probably will not make much of a difference at all that could be noticed, so personal preference on what you like.. my .02
2011 Ford F-250 CCSB Lariat
-Bone stock
**Picture to Come**
ctrow89 is offline
post #4 of 8 Old 04-20-2013, 08:46 AM Thread Starter
Redlazer's Avatar
When I had 285s on my truck it seemed like I was getting better fuel economy than on the stock size tires.
CAROLINA GRAY BOY
Redlazer is offline
post #5 of 8 Old 04-20-2013, 09:08 AM
Joel's Avatar
Quoted: 10 Post(s)
A 20" rim weighs 10lbs more than an identical 17" rim
A 35x12.5r20 weighs 10lbs more than a 35x12.5r17 of the same mfg.
Stick with the 18s you have and that will help too.
I would go with the 285 if I were you, I believe the improvement in effect gear ratio will offset the added weight and look way better.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #6 of 8 Old 04-20-2013, 09:11 AM Thread Starter
Redlazer's Avatar
I have 16s on it now will be going to 18s
CAROLINA GRAY BOY
Redlazer is offline
post #7 of 8 Old 04-20-2013, 09:53 AM
Joel's Avatar
Quoted: 10 Post(s)
Right on! What I like about 18's is there seems to a lot of available sizes.
Joel is offline
post #8 of 8 Old 04-20-2013, 10:06 AM Thread Starter
Redlazer's Avatar
yea I think I'm going with the black n milled rockstars with 285x65r18s
CAROLINA GRAY BOY
Redlazer is offline
