Tire Size help - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 9 Old 04-18-2013, 03:13 PM Thread Starter
Tire Size help
What is the biggest tire size with leveling kit can I install on my 08 F250 Larriat?
I really like the look of 37's but I am being told that 35 is the largest I can go with a leveling kit.
enigma5 is offline
post #2 of 9 Old 04-19-2013, 12:36 AM
BIG Laing's Avatar
On the stock wheels? There are some guys on here rocking 37's on aftermarket wheels with just a leveling kit. Granted they are not doing any serious offroading.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 9 Old 04-19-2013, 06:02 AM
KS_
Quoted: 22 Post(s)
37''s will work if you don't mind a little rub on turns
KS_ is offline
post #4 of 9 Old 04-19-2013, 11:46 AM Thread Starter
Thanks for your reply, no i am also looking at aftermarket wheels. Will not be doing any serious offroading, just towing my toy hauler and sometimes on the sand.
enigma5 is offline
post #5 of 9 Old 04-19-2013, 11:56 AM Thread Starter
thanks for your reply, will it rub even with aftermarket wheels... also, i tow my toy hauler and sometimes to back it in to camping spots i need to turn my wheels to the max... so i don't think rubbing is an options for me.
enigma5 is offline
post #6 of 9 Old 04-19-2013, 02:31 PM
KS_
Quoted: 22 Post(s)
I couldn't tell you exactly. I know that those are a considerable amount bigger then stock so turning you may get some rub.
  • Kaleb - 97 F-250. 1.0 housing, WW2, 3 inch dp to 3.5 straight pipe, TS 6POS chip, Riffraff 6637 Intake, 4" Rough Country Suspension Lift and 33"s.
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
KS_ is offline
post #7 of 9 Old 04-19-2013, 02:38 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
ths largly depends ont he wheels you intend to run. i can just BARELY clear my 33s with my 2.5" leveling kit at full lock, but im running deep dish 20x12's.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #8 of 9 Old 04-19-2013, 02:51 PM
BIG Laing's Avatar
You will rub near full lock with 37x12.5 on the stock 8" wide +40 offset wheels.
If you buy the right wheels you will only rub slightly at full lock on the radius arm, and clear your fenders completley. I would suggest a 9" wide wheel with an offset between +20 and +15. If you go with something bigger then +25 you will rub the radius arm. If you go with an offset smaller then +10, you run the risk of tearing up your fenders.
post #9 of 9 Old 04-19-2013, 05:34 PM
While we're on tire ps. I have a 2wd OBS dually what is the largest tire size I can go without rubbing?
95 PSD, dually, 2wd, 5 speed, boost gauge,EGT gauge, 3in downpipe, 4in exhaust straight pipe- flo~pro kit, max micro superchips tuner.
7.3hunterbaker is offline
Tags
level kit , tires
