Long lasting trailer tires? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 04-17-2013, 04:11 PM Thread Starter
Alright guys, I have a lawn care and landscaping business. One of my most used trailers is a 16' heavy duty dump trailer. It's a 14,000lbs gvw trailer, that I use for everything. Right now I am going through tires like crazy! Most of my work is done in a single community, which is full of round-a-bouts and tight turns. Every few months I'm replacing all four. I desperately need to find something that will last. Right now the trailer has 235/85/16's. I have tried a dozen brands, and all wear out in no time. Any ideas? I'm open to changing wheel size or just about anything else. Thanks!
CobraChris is offline
post #2 of 7 Old 04-17-2013, 04:13 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Are you using ST tires or LT tires?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 7 Old 04-18-2013, 09:19 AM Thread Starter
They are ST tires. Also, I have had the cheap Chinese brands, and the expensive USA made. It really didn't make a difference.
post #4 of 7 Old 04-18-2013, 09:29 AM
fordpwrstroke7's Avatar
Spend the money and get some 14 ply tires. I haul tandem duals and these tires are by far the best that I have used.
2008 F-350 CCLB
2004 F-250 CCSB (sold)
1997 F-250 CCSB (sold)
1994 F-250 ECLB (sold)
fordpwrstroke7 is offline
post #5 of 7 Old 04-19-2013, 04:39 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Doesn't matter who makes them, but ST tires are just not gonna hold up. The big G rated, 14 plies are super duper.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 7 Old 04-19-2013, 05:01 PM Thread Starter
Correction! I could have sworn that they were ST tires, however I was wrong. Looking at them this afternoon, they are LT tires. They are Trailer only LT's. Also, I'm not sure of the ply, but have a weight rating of 3700lbs @ 85psi. So, I guess I'll start looking for some G rated tires. Hopefully they last. At Between $180 and $275 a piece (currently), I cant stand replacing them every 4-6 months.
post #7 of 7 Old 04-19-2013, 05:12 PM
It's your application that's eating them up lots of turning wears them out because they skid on the ground when you turn. I pull a 53' wedge trailer for a living and I've had best luck with Firestone transforce at's. I also have them balanced and rotate them about every third oil change on the truck that pulls it. I usually get about 70k out of them.
I've tried the g rated tires as well and they didn't hold up as the firestones.
Just my .02
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
