Need wheel advise!! - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 04-04-2013, 10:33 AM Thread Starter
boatpilot's Avatar
Need wheel advice
OK guys, got 4.5" carli starter coming for my 2012 with their high mount stabilizer...trying to decide if I should run 35's on my kr 20s or go 37s on 18x9...don't know squat about quality aftermarket wheels so asking for help if I decide to go that route...I know I need 5-5.5" backspace to fit 37s, no chrome, no black, want something with a finish that will hold up off road, no bead lock, something original....ideas? Suggestions?
Thanks
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #2 of 4 Old 04-05-2013, 09:28 AM
I have the same lift set up and was running the stock 20in wheels w/ 295/65/20 nitto trails, I just odered a set up 18x9 Method Standard's in black and a set of 35in Toyo Mt's. I didn't want to go to 37in and wanted a slightly softer ride which is why I went down to the 18in wheels.
I know you said no black, but they make the same wheel in a regular aluminum finish that looks good. I think they're a relatively simple design.
-John
2012 F350 6.7L CC/SB, Carli 4.5" Pintop, 315/70/18 Toyo MT, Method Standard Wheels, Icon Dual Stabilizer, Mini-Max, S&B intake,Line-x, Access Bed Cover, Titan 50g, AMP power steps
ktmrider is offline
post #3 of 4 Old 04-05-2013, 09:51 AM Thread Starter
boatpilot's Avatar
Thanks, I'll give em a look. So the nittos in 295/65 are real stiff?
2012 F350 KR
post #4 of 4 Old 04-05-2013, 10:47 AM
yes. i run them at 40/35psi fr/rr so they're not too bad. I wanted to get new wheels anyway, in doing so figured I'd change things up.
-John
ktmrider is offline
