Quick Rim Question (Lip Depth for Deep Dish) - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 9 Old 04-03-2013, 02:57 PM Thread Starter
Quoted: 33 Post(s)
So Im at a cross roads. I want the 20inch Fuel Throttle rim, but I dont know if I should go with the 20x10 or the 20x12 rims. I want the nice deep dish look. My question is, does anyone have the lip depth for each rim.
Are the 20x10s lips smaller than the 20x12 rims? If anyone has the lip depth for 20x10 and the lip depth of 20x12 that would be AWESOME! I cant tell if the 20x10s are smaller or the same. I really hope someone can help me out with the depth of each rim. Thanks in advance guys! I wanna order these as soon as possible!
Tony Smith
2006 F250 Fummins with Allison Transmission
Fully loaded with all the goodies
Planning: Carli 4.5" Backcountry with full deaver upgrade
LTSmith is offline
post #2 of 9 Old 04-03-2013, 05:35 PM
Fuel Hostage 20x12 -44 . Hope this helps ya
JIMS SVT is offline
post #3 of 9 Old 04-03-2013, 10:26 PM
BIG Laing's Avatar
Depends on the offset of each wheel. A 12" wide wheel with a 0, -24, -44, ect... will all have different "lip depths".
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 9 Old 04-03-2013, 11:36 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The 20x12's have all the extra width added to the outside of the wheel, so they have 2" to 2-1/4" deeper lip than the 20x10's.
Here is a link to the 4wheelparts info on those wheels, if you compare the backspacing on each you will see that the 20x10's have 5" and the 20x12's have 4.75" which means that the outer edge of the 20x12" wheel is 2-1/4" out farther from the hub.
Chrome - Wheels
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 9 Old 04-04-2013, 12:24 AM Thread Starter
Quoted: 33 Post(s)
Thanks guys! I think I'm going to go with the 20x12 with -44mm offset. I just wasnt sure where the extra depth went between the 2 different sizes. Thanks for the pics, the offset explanation and where that extra depth went. I appreciate the quick replies as well!
Tony Smith
LTSmith is offline
post #6 of 9 Old 04-04-2013, 12:53 AM
BIG Laing's Avatar
What tires you going to run? Your stock wheels were 8" wide 0 offset so about 4.5" backspacing (to the wheel not tire). Those 20x12 -44 have about 4.75" backspacing. What I am trying to say, is if your getting a wide tire, you will be rubbing the leafs...
post #7 of 9 Old 04-04-2013, 01:15 AM Thread Starter
Quoted: 33 Post(s)
I was going to get the Toyo Mt 37x13.5x20 tires. Currently I'm running 35s on 16s. Not sure of the offset or backspace on them now since they're painted. But the lip depth on them is about 5 inches I believe. The tires I have now I'm pretty sure (not gonna go look since its 115am right now) but if I remember correctly, they are 315/75/16 which is 35x12.5x16. And my tires don't rub at all. Going with the bigger rim with the larger offset would help keep the tire away right? Basically just increasing the rim and tire size so it would be the same distance as it is now?
Tony Smith
LTSmith is offline
post #8 of 9 Old 04-04-2013, 02:33 AM
BIG Laing's Avatar
13.5" should be ok. Slight rubbing near full lock. Just glad your not doing 15.5"+.
post #9 of 9 Old 04-11-2013, 10:44 AM
Nonevo's Avatar
Im looking to do something similar to you but the issue im having is not that it will rub on the inside, its that with the wider rim pushing the tire further out, which causes clearance issues with the tire rubbing the backside of the front fender at full tilt.
I have 37's on an 18x9 with 4.5" BS and -12 offset and when I turn the out edge of my tire is only about .5" from the back side of the fender.
Just something to consider.
2014 F-350 CrewCab LWB FX4
SOLD - 2005 F-350 CrewCab LWB Fx4
8" fabtech lift, 37x13.50 Toyo MT's, 22" American Force shift, N-fab RSP front bumper w/ (4) 9" Pro Comp lights, Amp steps, Magnaflow exhaust, SCT Tuner, Recon smoked running lights and mirror lenses
Nonevo is offline
