37 in Toyo MT air pressure - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 03-22-2013, 01:18 PM Thread Starter
Finally bought some 37 in. Toyo MT`s mounted on 18x9 rims. The tire shop said that the sweet spot for these tires is between 35-40 lbs. pressure for the street and to never inflate over 50 lbs. which is the max for these tires. I did a search and seems like most here are at 50 or above, so trying to figure this out. Truck is a 2012, should i leave them at 37 lbs.? which is what they are at now.
RH67 is offline
post #2 of 5 Old 03-22-2013, 02:00 PM
BIG Laing's Avatar
Chalk line test it.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 5 Old 03-24-2013, 03:19 PM Thread Starter
Originally Posted by BIG Laing View Post
Chalk line test it.
So far 40 lbs. seems to be the magic number with the chalk line test.
RH67 is offline
post #4 of 5 Old 03-24-2013, 03:33 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
I think most are running 40 to 45 psi
Big_Smokey is offline
post #5 of 5 Old 03-28-2013, 06:04 AM
Bad Superduty's Avatar
Learned this along time ago from Smokey Wren and works very well with tire wear and payload concerns. Take your max PSI rating and the max load rating listed on your side wall. I'll use my new tires (for example) which are 37x13.3x18's with a max load of 3520lbs @ 50psi. My truck empty with no load weighs 8500lbs. 5000 lbs. up front and 3500lbs. in the rear. I used my local Flying J scales to get exact numbers.
I divide 50psi into max load 3520 which equals 70.4lbs per square inch. So each 1lb of air yields 70.4lbs of support. I take my rear weight at 3500lbs and divide 70.4 into that number. The total is 49.71psi. I have two tires in the back, so i divide 49.71 by two which is 24.85 or lets just say 25psi in each of the rear tires. Moving on to the front which is supporting 5000lbs so I divide 70.4 into 5000lbs which equals 71.02 and then divide that by two for each front tire. That equals 35.5. So with the current weight of the truck I run 35psi up front and 25psi in the rears. The tires are perfectly flat with the chalk test and you get a good contact patch with the correct psi for supporting the truck's weight.
If you added weight to the front with a replacement bumper or weight to the rear with a load or trailer, you recalculate using the same formula with your new weights/load. I have used this on all my trucks for years and have had excellent, even wear with the best ride.
Just my two cents but works and is exact for supporting the loads you are carrying.
Cheers,
2012 F-350 King Ranch
Bad Superduty is offline
