what offset wheels for 20x12 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 03-21-2013, 05:43 AM Thread Starter
I have an 04 with leaf springs and it came with 20x12 M19's not sure the offset how would I measure that? I had 37x12.50 and it was fine now i have 38x13.50 and they rub when turning at lock. What offsets are people with leaf springs running on 20x12 with no rubbing?
PowerstrokeAaron is offline
post #2 of 6 Old 03-21-2013, 03:02 PM
BIG Laing's Avatar
Should be stamped on the rim. If you pull a wheel off, look for it. To go 1" wider tire with no rubbing, you will need to go to a rim at least 12mm smaller of an offset.
So if you have a -44. Go to a -56 with the same width wheel.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 6 Old 03-21-2013, 06:03 PM Thread Starter
is it measured from the front lip of the wheel to center of the hub where it mounts? Kind of like the opposite of back spacing and in metric?
post #4 of 6 Old 03-21-2013, 06:28 PM
BIG Laing's Avatar
Offset is mounting face to centerline of the wheel. Backspace is mounting face to backside of the wheel.
post #5 of 6 Old 03-22-2013, 05:26 AM Thread Starter
i looked but cant see any marking, my wheels are pretty beat up. If it has 4.5" backspacing and its a 20x12 so the centerline would be 6". So would it have a -1.5" offset or -38 converted? and I should be good no rubbing with a 6mm smaller offset since the tire is 1 inch wider it would be 1/2 an inch on each side?
post #6 of 6 Old 03-22-2013, 12:08 PM
When all else fails, I cheat and go to this site.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
The fact is, back spacing is for old guys like me. If you don't want to look like a tool when you go buy wheels, then you need to learn how off set works. As Master Yoda taught us: "You must unlearn that which you have learned."
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
