315/70/18 tires on stock 18 inch wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 17 Old 03-19-2013, 05:08 PM Thread Starter
does anyone know if u can fit 315/70/18 tires on stock 18 inch wheels?
2005 f350 king ranch is offline
post #2 of 17 Old 03-20-2013, 01:25 PM
Discount Tire's Avatar
Quoted: 9 Post(s)
With a leveling kit installed you can run tire size 315/70-18 but your factory wheels have to high an offset (like BIG Laing noted) which means the tires will rub on the inside towards the suspension. A lower offset wheel will is recommend for this size.
Low Prices! More Choices! FREE Shipping!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
Discount Tire is online now
post #3 of 17 Old 03-20-2013, 05:18 PM
BIG Laing's Avatar
On an 05 you will have severe rubbing on the stock +40 offset 8" wide wheels.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 17 Old 03-22-2013, 11:06 AM Thread Starter
great thanks guys. how about with a 4 inch lift do u think i will still rub
post #5 of 17 Old 03-22-2013, 12:31 PM
BIG Laing's Avatar
You will still be rubbing on the radius arm with a lift.
post #6 of 17 Old 03-22-2013, 05:39 PM Thread Starter
so what size tires do u recomend?
post #7 of 17 Old 03-22-2013, 06:22 PM
BIG Laing's Avatar
315/70r18 is awesome, but not on stock rims. You really should be sticking with 285 or 295 wide on the stock rims IMO.
post #8 of 17 Old 03-23-2013, 09:44 AM
Bad Superduty's Avatar
You can but will rub the radius arms at full lock like others have stated. I have been running my Toyo Mt's 315/70/18's for a year now w/a leveling kit and it hasn't bothered me too much.
I am putting on a Carli 4.5" kit next week and will be running 37" Toyos on my factory wheels. I know the radius rub will be even worse so I am going to try using Fred Goeske's 2" steel hub centric adaptors to bring my factory wheels out and see how that works.
Cheers,
Name:	2012 F-350.jpg
ID:	86338   Click image for larger version
ID:	86346   Click image for larger version
2012 F-350 King Ranch
Bad Superduty is offline
post #9 of 17 Old 03-25-2013, 11:14 AM Thread Starter
great. thanks guys. how noisy are those m/t tires anyway
post #10 of 17 Old 03-25-2013, 12:32 PM
Over stock there is a slight hum but no drone, you know they are there but very livable. Very quite compared to the MT`s of the past.
RH67 is offline
