will these wheel work - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 02-28-2013, 09:34 AM Thread Starter
LEARNING AS I GO
bck4more's Avatar
So im trying to figure out if these will work with out rubbing. I have concerns about the backspacing and offset
Moto Metal Part W/P9516987312 - MO951, 16x9 with 8 on 170 Bolt Pattern - Black-RH2
The tire im buying is 38x14.50. Really needing some help here guys thanks like always
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 4 Old 02-28-2013, 10:26 AM
For backspace/offset questions, I like this site. Utilizing this site, I don't need to "be able do 3rd grade math" to convert off-set (f'in PITA way to measure rims) to back space (much more consistant). 1999-2004 can use 4.25~4.5 back spacing, IMO, anything deeper is going to create more contact issues.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
I used 365/75-16 to simulate the 38x14.50s you were asking about.
Depending on the backspace/off set of your existing 18x9s, you could use that as your base line. I have run 14.5s on a 10 inch wheel with about 4.5" of back space, they rubbed at near lock the leaf springs near lock. But I only have a 4" lift and those were 35s, so your results may vary.
However, having seen those same 14.5 Toyos on 12" wheels in my friend's garage, I wouldn't run 14.5s on anything less than a 12" wheel if I had the chance to do it again. Like a dumbass, I rolled those Toyos at 50psi all the time, well, the centers were nearly bald and the shoulders still had plenty of tread.
We have 38X15.50-16s on our 1/2 truck, to get a decent tread patch on a 10" Weld, I have to run them at 25 psi.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 4 Old 03-01-2013, 01:07 AM
BIG Laing's Avatar
Not this again
-2 + 5 = 3
5 - 2 = 3
They give you the exact same thing. Just because you don't understand both, doesn't mean one way is wrong.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 4 Old 03-01-2013, 08:59 AM
Originally Posted by BIG Laing View Post
Not this again
-2 + 5 = 3
5 - 2 = 3
You fell for that one hook, line, and sinker, BIG Laing!
I only made those two references to see if you were reading this or not. Thanks for playing along.
BTW, I do like that link because I don't have to "know 3rd grade math", I just plug and play and the number gets spit out to me
Karls03 is offline
