Another Backspacing Question, Sorry guys lol - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-26-2013, 03:14 PM
Sorry, I know this has been beaten to death, but I dont have much time before I head out to work to search the forums.
Will this set up work for my truck:
Fuel Wheels Part M53120201747 - D531 Hostage Deep, 20x12 with 8 on 170 Bolt Pattern - Black-RH2
Its Offset: -44mm and Backspace:4.75
With these tires:
Toyo Tires Part 360220 - 37x13.50R-20LT, Open Country Mud Terrain -RH2
With these tires and the rims with that offset and backspacing, will they rub or will everything fit ok? I have an 01 F350 SRW sitting on a 5.5inch lift. Just wanna make sure I'm ordering the right rims. Thanks! And sorry, I know its been asked so many times before
Old 02-26-2013, 05:10 PM
the width will hurt you, if it was a 9-10", you would be money !
Old 02-26-2013, 05:31 PM
Will the offset and backspacing be ok though? I shouldnt have any issues with that though will I?
Old 02-26-2013, 05:50 PM
i would look for a close to 4.5 bs. a 37 with 4.75 will touch the leafs pretty good.
maybe even with 4.5, a safe bet would be 4", but that kills the width idea.....
all i can say is measure it ! play with some cardboard, and make templates.
Old 02-26-2013, 05:52 PM
let me explain...
take a piece and cit the diameter you want ( over all ) IE>>>37"
take a second piece and make a cap ( cylinder shape ), you can then slide it , in and out, turning the wheel, and do some measuring.
