Sponsored by Discount Tire |
16.5 on a 2006 f250?
I know this has been covered 1mil times but in in a argument with a buddy of mine he says they'll fit I don't see it would one of you with more knowledge than me please help me. And truck is completly stock
Re: 16.5 on a 2006 f250?
If your talking about fitting over the brakes, they should. I originally had 16" wheels on my 2003 F350.
Sent from my SPH-L710 using AutoGuide.Com Free App |
Ok cool I thought I read somewhere that 2005 and up the changed the calipers and hubs I honestly don't know. Is this right?
Yes they did, everyone says that you can't put anything less than a 17" on 05 and up. I have not seen a 16.5 on 05 and up though.
my 04 srw came with 16's. my 05 drw came with 17's and the bolt pattern is different.
bailey |
05 has bigger brakes. if you grind on the calipers 16's will fit on a 05 and newer.
mike |
16.5's on ANY TRUCK
Just food for thought here. I had 16.5's on my truck and had a blow out. It nearly flipped the truck BECAUSE there is NO safety bead to keep the dang thing on the rim. I would never try what your trying to do simply because of that and that alone. SAFETY is and should be your Number 1 concern then the other reasons you're doing it.
Like I said, food for thought. |
Agreed
and the reason 16.5 tires are harder to find I still have a set on My 81 fullsize Blazer and the safety bead issue had just became a big deal when I bought them years ago |
The bolt pattern is not different both are 8x170
