Tire & wheel help!!! - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-19-2013, 10:41 AM
My 2013 f350 platinum is almost here and i have a question about my rims and tires im ordering. I will be doing a 2.5 inch level kit with a 35x12.5x20 rim and the rim is a 20x9 with either the offset of +1mm or +20mm and i dont know what to order!!! the +1mm i was told may rub but cant get straight answer please help!!!! anyone have a set up like this or know the answer???? Thanks alot!!!
Old 02-19-2013, 10:06 PM
Both of those will work fine. The +1 will stick out almost 1" father then the +20. IMO the +20 9" wide wheel is perfect for 2.5" leveling kit. (that is what I am going with in the near future)
Old 02-20-2013, 06:17 AM
Vlxjim did an awesome set up on his truck and is running 20's +1 with 325x60's (35x12.5ish) on an ICON 2.5 s2. IMO I think his truck looks BA and is exactly what I'm going to do to mmine one I can decide between ICON and Carli. Here is his write up New ICON 2.5 & Wheels and Tires. If that doesnt get you there, search "dynapro ATM ICON" in the search engine up top...
Old 02-20-2013, 09:49 AM
Would you go with the +1 or the +20?? Also why put blocks in the rear with just a level kit?
Old 02-20-2013, 10:03 AM
IMO a little wider stance looks tough. I am considering +1 and -12, but it is all personal preference. Blocks depend on the kit and the truck. I believe with alot of the good 250 kits you need to upgrade blocks. 350's not so much except some kits do require 250 blocks for proper leveling. There are definitely alot more qualified people on here that can explain the methods to the individual kit madness, but alot will boil down to your individaul need/use of the truck and bank account.
