Sponsored by Discount Tire |
99-04 16x10 offset help
I'm wanting to put 16x10 wheels with 305/70/16 tires on my truck. There's about 4 different wheels I like but they all have different offsets. They are 24 25 32 38 and I think I saw one over 40. How will the offset change the look between all those. Thanks.
The only thing the offset affects is how far out the tires sit. the higher the offset the more they will stick out. a 16x10 rim is a 16x10 rim no matter what its how far the mating surface is in relation to the outside of the rim
Re: 99-04 16x10 offset help
I have 16-10 w/ -24 offset on the red trk with 315-75-16 tires... any more neg offset yhan that pulls the tire inside the wheelwell more... then tire rubs leaf springs.
Sent from my SCH-I200 using AutoGuide.Com Free App |
So a -38 will stick out further than a -24?
Anyone? I'm getting ready to order these but want the ones that stick out the furthest
Yes a -38mm offset will stick out farther. But then you run the extra risk of rubbing on leafs. -24mm seems to be the perfect number. But it doesn't throw your tires way out there, maybe around 2 inches.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Thats a good website to get a visual of the different numbers. |
Yes a -38 will stick out farther heres a picture explaining it
So +40 is high (sucked way in), 0 is stock (99-04), and -40 is lower (sticking way out). |
Perfect thank you.
