Originally Posted by TheRobenator
Hello,
I am looking at purchasing a set of XD monster wheels that are 20" and a set of toyo MT's that are 37". Do the monster's stick out enough to not scrub? I want them to stick out maybe 2 inches past the fenderwall cause I like that look, will these do that?
What kind of offset should I need?
ANd if you have pictures of you running these 20"s on your F250, can you post them?
Originally Posted by Big_Smokey
U need to read up on offset or backspacing. Those xd monstera are 20x9 if i remember and -12 offset. I'm not sure how far they stick out in inches but my wheels are the same width and offset. The pocket bushwackers cover them perfectly, which I think is 2 inches of coverage. Dont have a pic
I've worked at a tire shop for 3 years of my life, I was mearly asking what offset I need to run for them to stick out enough in my F250, and yes XD monster makes 20x9's, but as I said above, these are the 20x10 model. With a -18 offset. So your saying they stick out 2" with yours so they will stick out just a little bit more with mine, thank you.
Your first post has no info on the wheel width. Also how wide of a 37" tire you looking at?
+40 is stock wheel on 05+. So -18 is 58mm farther out. 58/25.4=2.25" farther out centerline of the wheel.
2.25" Plus 1/2 the extra width of new tire compared to stock, is how much farther out from stock the tires will be sticking out.
