Terra Grappler PSI - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-05-2013, 04:21 AM
Terra Grappler PSI
Had a set of 295/70/18 Terra Grapplers installed on my 2011 4x4 Crew Cab last week. What would be the ideal psi to run in them to obtain the longest treadwear possible. I also pull a 6k pound trailer 5 days a week. Any input would be greatly appreciated.
Old 02-05-2013, 05:51 PM
I run my rears at 65 when towing, and fronts at 42. Seems to wear pretty good, about 20k on my terra grapplers so far and all even
Old 02-06-2013, 08:14 AM
I would run 70psi all around.
Old 02-06-2013, 10:11 AM
The tire store I got them at filled them to 70psi. Im just not really wantin to be buying another set 6 months from now.
Old 02-07-2013, 01:56 AM
I have the exact same tires as you. From what I read, 65psi all around until you are towing/hauling real heavy. Then 80psi in the rear and 70 front.
That trailer has a 400-1000 tongue weight? Should be fine for 65psi.
