Sponsored by Discount Tire |
can I fix my speedo and tranny shift and odometer?
Tire size increase?
I was at the ford dealer, and they plugged their computer into the little port and there was an option for tires. he put in 275/65/20 which is the same size as my 35's and the speedometer is still off. Makes me think that the odometer is off too as well as shifting and everything else. can I fix all this? |
275/65-20 should be about 34". That's probably the issue.
34.08x3.14=107" 35.00x3.14=109.9" Your speedo should only be off about 2.5% off. What are you seeing? |
Your odometer should be off 2.5% too. I don't know why you are worried about tranny shifts. Millions of people run a much larger difference in tire sizes without a problem. When you go up 4-5 inches or more in tire diameter, is when some people start re-gearing there trucks. I went from 32.8 to 34.5" tires and never had any issues...
according to my GPS my speedometer says 65 and I am doing 70. when it says 70 I am doing 76
Just thought it had a negative effect on everything about the truck if it was not correct. Are you saying that I can just leave it like that? |
Thats 7.5% off... wonder why it's that far off? I would not be worried about it at all.
Good hunting! |
70mph/76mph = .921 for a 7.9% rate of change or error rate 31.5 OEM tire/34.08 current tire = .924 for a 7.5% rate of change or error rate The numbers don't lie, but the dealership sure did. I don't know about your 2003, but mine shifts the same whether it's on 31.5s or 35s. When I say the same, I mean at the same INDICATED speed. 45 mph indicated, light pedal pressure, converter locks. However, on my 315s I have a GPS speed of 49 when it locks. Last edited by Karls03; 01-31-2013 at 06:42 PM. |
I did some more math for you (tire/gear/rpm/speed/336) and assuming that you have a 3.73 gear, here's what you should see on your tachometer at 70 mph INDICATED.
Uncorrected speedo: 1979 let's call it 2000 rpm for argument's sake. Corrected speedo : 1829 this would be just above the small line below "2" on your tach. Because your GPS shows more than your speedo, I'm thinking that the first one is what you are seeing. SCT told me a few months ago that while the 2005 and up was reprogrammable through their unit (OBDII port interface), but the 2004 and below speedos read through the ABS and are therefore harder to recalibrate. |
