6.4 rims on 6.0? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 01-24-2013, 11:21 PM
6.4 rims on 6.0?
any body have any pics of a 6.0 with the 6.4 20" wheels? thinking about trading my 20" moto metals for a set of factory 6.4 20s but cant find pictures any where... please help
Old 01-25-2013, 12:20 AM
If you have an 04 the wheels will not fit without a spacer... 08+ had +40 offset.
Old 01-25-2013, 12:53 AM
O ok well i have a set of 2 inch spacsrs if i use them will they work thank you in advance
Old 01-25-2013, 04:04 AM
Please tell me they are hub-centric. I think 04 and older had 0 offset so 2 inch spacer is 53mm thick and you will have wheels sticking out 13mm or 1/2" farther out then stock, so it should work great.
Old 01-25-2013, 02:45 PM
So what about the 5 spoke 20" rims off of the '05-'07 would they fit on an '08? Those would be the only rims I would buy for my truck.
Old 01-25-2013, 04:01 PM
05'-13' SRW are the same offset. So they can be switched between trucks with no issues. 99-04 had leaf spring front suspension. 05+ have coil suspension.
The only time I think you would have trouble would be trying to put 11+ 20" wheels on a 05-07 2wd truck as they are too tall (34.8").
Old 01-25-2013, 04:06 PM
11 up still use 275/65/20's right. If so thats the same size as the 05-10 trucks put on their 20's
Old 01-25-2013, 04:43 PM
275/25.4= 10.8x1.3 = 14.7+20 = 34.7" Sounds right to me.
I didn't know 05+ had that tall of a tire.
I guess the only time you would have a problem is trying to put 05+ 20" wheels on a 2wd truck.
Old 01-25-2013, 04:45 PM
couldn't you get 20's on a 2wd truck from the factory?
Old 01-25-2013, 04:54 PM
HEre is my 04 with 08 20s with 2 inch spacers.
